incontenant buffalo carbs
Posted: Thu Jun 17, 2010 6:44 pm
by two-stroke-brit
hi guys ,i am suffering from a strange malady,
i have been using the bike to ride to work to try an hurry along the breakin of the new cylinders etc.
i leave at 5am and regulary but not always the center and/or righthand carb flood when i pull up to the first light and then on until i get to work (7 miles).
i turn it off and leave it until lunchtime when i use it again and it never floods until the next morning.
it is texas and 75 degrees at 5am ,95 by lunchtime.
i have had the carbs apart so often i can do it in my sleep.
i have also changed the float valves to no avail.
any clues
thanks mark.
Posted: Thu Jun 17, 2010 7:05 pm
by Suzsmokeyallan
Mark did you inspect the brass seats the float valves sit in??? If the seat is compromised a new valve wont fully cure the problem.
thanks allan
Posted: Thu Jun 17, 2010 7:15 pm
by two-stroke-brit
thanks allan you may be on to something as i did change the left hand seat along with the valve.
will swap out the others this weekend,
cheers mark
Posted: Thu Jun 17, 2010 8:31 pm
by Suzsmokeyallan
Dont forget the little red gaskets need to be good too, if not, well more leaking will come your way.
float not
Posted: Fri Jun 18, 2010 8:03 pm
by two-stroke-brit
hi i think i have finaly sorted it ,
(all the carbs have new valves and seats now)
still floods
then i remembered reading on here that someone had a damaged float that caused intermitant flooding so i changed out the float and presto fixo .
not flooding now .
i should wait for a week of use without incident to pronounce total success.
plenty of false dawns when i thought i had fixed it before.
Posted: Fri Jun 18, 2010 10:41 pm
by oldjapanesebikes
Sounds like good news !!
Posted: Fri Jun 18, 2010 11:41 pm
by rngdng
Leaky floats can drive you crazy! I hope it's fixed.
Posted: Sat Jun 19, 2010 8:04 am
by Suzsmokeyallan
Mark what can i say, im shaking my head here,,,,, bad seats AND leaky floats. Those are brass floats, were they physically damaged or did they look good???
Posted: Sat Jun 19, 2010 10:18 am
by Suzukidave
Thats on my personal list when i have the carbs apart .. to give the floats a shake to hear if there is gas inside them . If there is .. time to replace
Posted: Sat Jun 19, 2010 1:31 pm
by Suzsmokeyallan
I totally agree there Dave, thats why I'm wondering if they were leaking and had in gas how Mark could have missed it.
fingers crossed
Posted: Sat Jun 19, 2010 3:54 pm
by two-stroke-brit
the floats looked ok to me and i didnt notice any signs of damage, but it was worth a try and it worked.
i also dont understand how the prob would be so intermitant but my fingers are still crossed.
i should know if it stays good for a while.
but where would the fun be in that.
is the gap a bi anual event ,sping and fall ?
thanks mark.
