T20/TC250 stripped oil pump hole
Posted: Thu Mar 25, 2010 7:43 am
by doug rooney
OK, done it again from this endless taking apart and putting back together business. Stripped out one of the pump holes. I'm thinking going with just the one good bolt holding the thing on IS NOT wise. Stripped one will have a bit of resistance when tightening before it spins out loose. Being the dummy novice that I seem to be, shall I attempt a re-tap or take it somewhere? I do know I have to take the cover back off to do this. (Do know that much). Shall I go with some sort of self tapping bolt OR tap it out bigger and use next size up? OR...............Just take it somewhere knowing how much I've screwed (no pun) this thing up thus far?? Thanks, Doug
Posted: Thu Mar 25, 2010 10:36 am
by advant63
buy yourself a helicoil kit. or better yet timeserts. it's easy and next to free once you've laid out money for the kit.
Posted: Thu Mar 25, 2010 10:43 am
by doug rooney
Thanks advant.. Not familiar with timeserts. Will do some research on those. Appreciate it!!!
OK, tons of metric time-set kits on ebay. Any recommendation for which kit to buy to cover most Vintage bike needs that may arise in the future??
Posted: Thu Mar 25, 2010 12:18 pm
by oldjapanesebikes
doug rooney wrote:Thanks advant.. Not familiar with timeserts. Will do some research on those. Appreciate it!!!
My metric heli-coil 'starter' kit actually came from Harbour Freight in the US - cheap as chips, but you get what you pay for. For replacement coils, and also for Time Sert kits, as well as Big Sert Kits, I have been buying from
this guy as the prices generally are much better than what I have seen locally here in Canada, even with the added shipping costs and exchange rates.
Posted: Fri Mar 26, 2010 7:55 am
by Suzsmokeyallan
I take it thats a 6mmx1.00 bolt or cross head screw. If you go to your local Napa dealer they sell the basic kits for a reasonable amount of money and you get a few inserts in the bag as well as the tools.
Posted: Fri Mar 26, 2010 8:43 pm
by doug rooney
Thanks guys. Learned something new again today. I can do this with the advice you've given! Most appreciative!
Posted: Sat Mar 27, 2010 1:08 pm
by doug rooney
Hi allan, were you referring to Napa having the helicoil kits or Time-serts?
Thanks. Just want to know what to ask for
Posted: Sun Mar 28, 2010 6:26 am
by Coyote
Posted: Sun Mar 28, 2010 7:49 am
by rngdng
doug rooney wrote:Hi allan, were you referring to Napa having the helicoil kits or Time-serts?
Most auto parts stores carry 6mm heli-coil kits. Time-serts are more expensive (and rightfully so), and less commanly found.
Posted: Sun Mar 28, 2010 8:12 am
by doug rooney
Thanks boys! Got it now I think.
Posted: Tue Mar 30, 2010 11:33 am
by Suzsmokeyallan
Hi Doug, it was a helicoil kit I was referring to, sorry for the late reply as I'm traveling.
Posted: Tue Mar 30, 2010 1:27 pm
by doug rooney
Not a problem Allan! Thank you!
