Plug caps???
Odin
Plug caps???
Post by Odin »
what plug caps should I be using with a B7HS plug?
its a T200, I asked about coils and thought I would first replace the wires and caps to see if that works, other wise I will replace the coils.
right now the caps are marked with LD05FP
thanks.
T200 (full restoration)
CL450 (on the go now)
T350 (sort of started)
"Even if the voices in my head aren't real, They have some pretty good ideas"
Isn't that the NGK 5K ohm resistance cap?
Good idea to try new leads and caps first.
Odin
Post by Odin »
tz375 wrote:Isn't that the NGK 5K ohm resistance cap?
I don't know, thats why I'm asking, I was trying to figure out what all the letters stand for.
L =shape 90 degree's
D =is the plug it fits (so the D fit's C/D type plugs, if it was B then it would fit plugs that start with B, I think)
05 =5K resistor
F
FP
EP these letter's I don't know what they mean and what is the difference between them.
I don't even know if my interpretation of the other letters are right.
I put a copy of the NGK de-code on my web site - and this is a direct link to the file you probably need..
Odin
Post by Odin »
oldjapanesebikes wrote:I put a copy of the NGK de-code on my web site - and this is a direct link to the file you probably need..
Thank-you so much, I was right about most of it and now it makes sense knowing the rest. but just to clarify the "F" would mean I need to screw that little cap on the spark plug off, right?
Never mind just figured it out.
thanks again.
Correct - best price I've seen for these (here in Canada) was at CTC, but the stock carried varies a lot from store to store. Happy hunting ! 8)
Jughead
This IS the real me!!!
Post by Jughead »
Stay away from the resistor caps if Possible.I've had nothing but trouble out of them.They left me stranded several times when I rode dirt bikes.
Hang me from the Tree of Shame.Damn! I forgot the Rope.
