Pinky (74 GT 750) has developed a leak. Yesterday I checked the coolant level and it was down a bit. Topped it off, started her up cold, and let her idle for a few minutes. Then coolant started disharging from the cooling system overflow/pressure relief hose. The coolant was only lukewarm. Took her for a ride, did not appear to loose any additional significant amounts of coolant, temp gauge stayed where it normally does. Let her sit overnight, started her up, and went through the same routine again.
Ideas??
Kevin
Water leak question.
- My new bike is "IRIS"
Everything Commeth
To He Who Waiteth
So Long As He Who Waiteth
To He Who Waiteth
From teh symptoms, it sounds as if the pressurization occurs at startup and doesn't continue to deteriorate as it heats up or runs.
That tends to suggest that it's not a head leak unless the head leaks until the block expands and increases pressure on the gasket (barrels expand more than studs and sleeve nuts).
If that were an issue, then you could try to re-torque the head.
Is it possible that there's some problem with the thermostat? It's an unusual design in that it when it gets hot, it opens the main hose passageway and closes off the bypass. If it's damaged in some way, could it be partially obscuring the bypass?
If the discharge is from the overflow tube, could it be something as simple as a malfunctioning rad cap. They are supposed to pressure test to 15 lb's, maybe it's just old and tired, like the rest of us. Well, some of us anyway. Cheers.
Fred
Fred
Suzuki GT 750s
Ducati 750 GTs
2007 Duc 1000 GT (the clone)
Suzuki RE5s
Ducati 750 GTs
Suzuki RE5s
You know, it did that to me one time. I never resolved it, as it quit happening. I think it may be the radiator cap as well, but it did happen before and simply went away. I don't know.....
I may have overfilled it. Not the raditor cap, unless I bought a bum one. This happed once last year, I figured the raditor cap, so replaced it. Now it has happened with the new radiator cap. I'll keep an eye on it and see what develops.
Kevin
Kevin
Everything Commeth
To He Who Waiteth
To He Who Waiteth
