dumb question
Posted: Mon Mar 08, 2010 8:40 am
by doug rooney
Awright, I know I should know this but on the T20 bottom case bolts, are they 8mm or 10mm? 2 of them take a 13mm socket and the rest take a 12mm but the thread diameter appears the same to me. Can't find the info anywhere. Thanks
Posted: Mon Mar 08, 2010 10:48 am
by Suzsmokeyallan
A 13mm socket fits them??, those cant be original bolts. Usually 8mm shaft bolts have 12mm heads and 10mm shaft bolts have 14mm heads.
Posted: Mon Mar 08, 2010 11:04 am
by doug rooney
NO, not original Suz. Paul miller replacements. Case solved I think. Caliper measures the outside of the threads at a shade over 7mm so I'm thinking they're 8mm even though the hexheads are different??
Posted: Mon Mar 08, 2010 11:27 am
by Coyote
Stainless bolts are generally 1mm larger on the head of any given size. So if you have a bolt that takes a 12mm wrench and you replace it with a SS one, you'll need a 13 to put it back in.
