Anyone else had this problem with T500 carbs?
Posted: Tue Feb 16, 2010 3:01 am
Just took the Titan away for a big weekend ride with our classic jappa group. After about 40 mins of riding, the revs would not shut off when I closed the throttle and then the revs began heading into the stratosphere
Thankfully, I had knowledgeable fellow riders who quickly isolated the problem to the left carb. Turns out that the locating/guide pin (that the slide moves up and down on) had worked its way out towards the outside of the carb. As a result, there was nothing to keep the slide in place and she moved, twisted and did a little dance whenever I tried to accelerate.
With a bit of the old Burt Munro spirit, we pulled a farmer's fence apart and used a wire nail to bang the pin back thru the carb body
After that, things stayed in place - tho I need to find a more permanent solution to make sure it doesn't slip out again. (? a bit of glue on the outside)
When we caught up with the group, I spoke with the other T500 rider who said the exact same thing happened to him about two months ago. Has anyone else experienced this?
