clutch ret nut
two-stroke-brit
Suzuki 2-Strokes: gt750
clutch ret nut
Post by two-stroke-brit »
how do you hold the clutch hub solid while you undo the retaining nut. :?
any help is most welcome.
mark
1973 SUZUKI GT750K.=SOLD
1982 HONDA CB900F =SOLD
1982 YAMAHA RD350LC.
1985 RZ350N
two-stroke-brit
more info
i should add it is a 73 gt750
1985 RZ350N
Frank
Country: USA (former Canuck)
Suzuki 2-Strokes: T500, GT550 (electric conversion), Hayabusa
Post by Frank »
I just undid the one on my old GT550 motor by holding it with a gloved hand and using an impact wrench. You might use a strap wrench also as a "hold back".
For regular hand tools you could weld a handle on an old steel plate and use that to hold the hub while loosening the nut.
A steel plate and a pair of thin vise-grips will also work, but in my mind, the air wrench is a MUST.
You really should get a clutch holding tool. John "bighole" Fry made a nunch of them to the Pinkpossum design .
PM him and see if he has any left or if he can make one for you. They are cheap and effective and much better than the vice grip types and they prevent damage to the clutch drum and basket.
A brilliant design, well executed.
two-stroke-brit
thanks
i used lanes advise of vise grips on the steel plate .
i also got an air impact wrench ,that makes life soooo much easier.
mark
1985 RZ350N
