How to check current size of T500 pistons?
MikeH1A
Post by MikeH1A »
My right hand cylinder is a bit rattly and I think I may have to look at new pistons and whatever else at some stage. To find out the current size of piston in there, I believe I can whip the head off and there should be a size stamped right there to see. Is this correct? Also, can I take the head off and just put it back without replacing the gasket. Should I use anything special to reseal it?
Thanks for advice
72 GT750J
71 TS250R
71 H1A
Buffalo-guy
Post by Buffalo-guy »
Suzuki pistons for your bike are marked with 0.5 (first over) or 1.0 (second over). If neither is there, then they are still standard size. If the head gasket is aluminum, then you should aneal the metal with a heat source (torch), and if it is fiberous material, then a good gasket sealant is required to do the job. New gaskets are best, of coarse. Suzuki rings for those bikes (I assume we are talking about the T500 and not the H1) are chrome steel, and very tough. The cylinder may also be what is worn, so new pistons alone may not fix the rattle. When the head is off, check for a ridge at the top of the bore, which would indicate a worn cylinder as well. Have fun. Cheers.
Fred
Suzuki GT 750s
Ducati 750 GTs
2007 Duc 1000 GT (the clone)
Suzuki RE5s
strainer
Post by strainer »
delete
parksie
Suzuki 2-Strokes: Suzuki t500 69,71,73, Gt500 76
Post by parksie »
I'm don't think I'd aneal alumninium head gaskets. Copper ones yes but not the aluminium ones.
1969 T500
1973 T500
1971 T500 (being restored)
1976 GT500 (being restored)
2012 Ninja 650
parksie wrote:I'm don't think I'd aneal alumninium head gaskets. Copper ones yes but not the aluminium ones.
Aluminum head gaskets can also be annealed . Before heating cover them with a coating of dish washing soap then when you heat the gasket with the torch when the soap turns black its annealed .
parksie
Post by parksie »
I stand corrected :oops: :oops:
1969 T500
1973 T500
2012 Ninja 650
MikeH1A
Post by MikeH1A »
Thanks for the info guys. I think I'll whip the head off this weekend and see what I have been running with and how she looks in there.
72 GT750J
71 TS250R
71 H1A
tygrant351
Post by tygrant351 »
im sorry but what do you mean "aneal" ? and how do you do it? thanks
tygrant351 wrote:im sorry but what do you mean "aneal" ? and how do you do it? thanks
Compressing a metal gasket material hardens it, and as there is generally nothing else wrong with it other than being hard (and so no longer malleable) to re-use it you need to soften it. That softening process is 'annealing' - copper and aluminium head gaskets are heated and allowed to cool and then can be re-used.
