more smoke from left cylinder
chainsaw
Post by chainsaw »
on my 76 gt750, a friend followed me home one day and noticed a significant difference in the amount of smoke coming out of the left outer pipe especially when I was wringing it out. you can also see it when idleing and blip the throttle.
any ideas on what may be the cause?
Dont believe in God ? Eternity is a long time to be wrong !!!!
Nope, but lots of them seem to do that. Pinky always smoked a little more out the left. Not a lot, but noticable. BlueBoy doesn't seem to do it.
My 550 smokes more out of the center cylinder. :?
The early SRIS systems dumped the two outside cylinders into the middle then they changed it http://www.3cyl.com/mraxl/gt/manuals/gt750man/sr48.htm
Mine is rigged per illustration 6 - 13.
Correction Mine is not hooked up per either of these illustrations. This is for the 750. My bike is a 550. The SRIS never changed on the 380 and 550 like it did for the 750. My hook up is:
Left crank to center cylinder
Center crank to right cylinder
Right crank to left cylinder
Coyote wrote:Correction Mine is not hooked up per either of these illustrations. This is for the 750. My bike is a 550. The SRIS never changed on the 380 and 550 like it did for the 750. My hook up is:
http://www.3cyl.com/mraxl/gt/manuals/gt ... 550-36.htm
Dave,
That's another great link. See the way it says to check the SRIS check valve, using a syringe? Easy and cheap.
