Arrrghhh! What the he$%, I can't believe this.
delete
Fred (nice name by the way)
Get rid of the corrosion as good as possible with wire brush, or other clever tool, then put JB weld in there to cover the holes. Should hold til another one surfaces. If a Water Buffalo bowl will fit, I have a few. Post some dimensions at the threads. Cheers.
Fred
Fred
Suzuki GT 750s
Ducati 750 GTs
2007 Duc 1000 GT (the clone)
Suzuki RE5s
Ducati 750 GTs
Suzuki RE5s
I had an old one....minute I will go look.
I believe I have what you are looking for. I will post up a photo Sunday and it's yours if you like it.
Terry
Fred, looks to be close, I am using a plastic mic/caliper, the best I can tell the threads are 25 and some change, top to bottom are about 23.5.
Send me your address and I will send it on the way.
Terry
Nothing received, send again.strainer wrote:Close enough, have sent you a PM.
Thanks Terry.
Terry
Mailed First Class international, probably take 2 plus weeks before you catch a glimpse of it.
It is pretty good Fred when you need those bits and pieces.
Terry
