Hagons for T500
Hagons for T500
I have a set of the Paul Miller shocks on my T500. After riding with them a few times I'm ready to upgrade to a set of Hagons.
But what length?
The PM shocks are 295 mm eye to eye. Hagons are available in 10 mm increments, so my choices would be 290 or 300. Axle clearance with the left muffler is a concern but I think the 300's would fit. I'll have to check the clearance more closely tonight.
I'm thinking of going with the 300 mm length so I don't slow the steering down any more. I actually like how it feels with the 295's. 290's might make it a little too sluggish, seems to me.
Debby
But what length?
Debby
70 T500-III
75 RL250
79 GS1000N
plus a few non-Suzukis...
75 RL250
79 GS1000N
Debby,
The 300mm shocks *should* work but you'll need to check the clearance on your specific T500. I've seen it vary from bike to bike. You can sometime loosen the two muffler bolts on each side and get the mufflers 1 -2 mm lower if you need the clearance. Make sure the cotter pin on your rear axle is bent so that the ends don't dig into the left muffler!
Jim
Jim
Oops. I measured wrong. I didn't have the bike on the centerstand and didn't have full extension. The new shocks are 305 mm, the old ones were 295. The extra length helped the steering I'd say, but the Hagons will have to be 300 mm. I can't go to 310, the axle nut would be touching.
Debby
Debby
70 T500-III
75 RL250
79 GS1000N
75 RL250
79 GS1000N
Debby.
You will be impressed with the way the Hagons work as apposed to the OEM.
My Buffalo was a much better bike with the change. About all the originals do for you is hold the springs in place.IMHO. Cheers.
Fred
Fred
Suzuki GT 750s
Ducati 750 GTs
2007 Duc 1000 GT (the clone)
Suzuki RE5s
Ducati 750 GTs
Suzuki RE5s
- johnakay
- I likes them jubblies
- Suzuki 2-Strokes: bike
Chain
One problem with stock muffers when using longer than stock shocks is chain adjustment. You have to take the left muffler off to get to the large nut with a box end wrench. It's a pain on the road using the OEM tool kit and Im on the road alot.
It isnt a problem with my after market expansion chambers, they are clear of the axle. Dofin
77' RD400 Stock
77' RD400 work in progess
76' Suzuki GT500A Titan 2 of 'em
76' RD400 frame, 79' rd400 Daytona bottom 77' top, 75' rd350 wire wheels, Factory products pipes
96' Honda PC800 for towing my RDs
shocks
On my GT500, I replaced the stock with a pair of 12-1/2" from Parts-n-more. BIG waste of money and effort. The axle nut just touched the muffler, had to lower the forks about a 1/2" to compensate for the weird handling. Looked good, but even on the lowest setting, it was like riding an old hardtail bike. Two up was barely OK, still a little stiff, but better than OEM. However I ride one up most of the time. Still can't do Hagons yet, so I got a pair from Reproduction Decals. Just put them on, MUCH better ride on lowest, a little firmer on setting two. Have not tried two up yet. The Parts-n-more shocks came with an adjuster tool, the Repro's did not and the tool from P-N-M would not work. Guess what, the steering head wrench that one of our boardmember's make works perfectly. So far Repro's to me, are good moderately priced shocks. They may not be exact copies for T500's, but at least it will ride a little better until you can get Hagon's, etc.
shocks
Were the Repro Decal shocks the correct length? Did you have the correct clearance from the lower shock mount and the exhaust??? I am also looking for the proper length shocks.
what good are expensive shocks if the run up against the exhaust?
Do the Hagons fit with no interferance.
77' RD400 Stock
shocks
The Repro Decal shocks are the correct length, maybe a 1/4" longer....feel a little heavier than the OEM units. I am about 250lb., so far setting two is a little too stiff, one maybe best for one up riding. Gyrocfi, from a picture of you on the Miss. breakfast run, even on one these might still be too stiff, but don't take my word on it. With shipping to Louisiana from Canada, the shocks ran $120 and change. From the 'fitting' charts for Hagon's they have the correct length, it's picking spring rate that is confusing for me. I have not seen a chart for recommended spring rates for weight loads, so I am unsure what to pick.
shocks
Thanks for the info on the Repo's. I ran the OEM shocks on my original new '76. I had a frame mount Windjammer fairing, saddle bags, luggage rack and loaded the thing down ALWAYS. sold it at 80K. I had no complaints but of course I didnt know any better, guess I still dont.
I would love the conveniance of being able to adjust the chain with out the hassel of taking the muffler off. guess its not all that much trouble BUT ya gotta concider the extra movement of the swing arm when you adjust the chain length. and I seem to have more chain stretch than everyone else?
Debb, sorry for Hi jacking your post!! Dofin
77' RD400 Stock
Dofin, try using a ratcheting tie down on the swingarm and the frame under the seat to compress it enough to turn the axle nuts. Loosen it to adjust chain, then compress again to tighten nuts. I put a heavy duty chain from 'Parts Unlimited' on my GT500, very little stretch so far. I think it was rated at 8000 lbs tensile strength....I am not sure. But the one I picked was higher (tensile strength rating) than most, but not the most expensive. A good bang for the buck.
