OH Crap
Posted: Thu Aug 06, 2009 8:40 pm
by Brett Kerby
Well got my new crank seal in and while putting the clutch back on, my make shift clutch hub tool slipped and I broke off 2 ears on my clutch primary carrier (not sure what it is called). Bike bandit says they are discontinued but looks like I can get a new piece from Interstate cycles. Question does the aluminum ear piece come off the primary gear piece?(not sure of proper terminology sorry) If so how? On the schematic it lists piece 1-1 and 1-2 for 85 and 126 bucks respectively....Help please...AND OH SHITE what have I done now.......Brett
geez
Posted: Thu Aug 06, 2009 9:10 pm
by Brett Kerby
OK fit of rage over and mind is working better now. Found a replacement on flea bay for under 20 bucks...... will make a better hub wrench tomorrow for sure..ignore first post please.........
Posted: Thu Aug 06, 2009 9:56 pm
by diamondj
Brett,
Motion Pro makes a clutch holder that works reasonably well for about $30 from Dennis Kirk, etc... They go for even less on the bay:
http://cgi.ebay.com/ebaymotors/Motion-P ... 06.c0.m245
If you got some extra steel plates with your replacement clutch basket and you have access to a welder, you can make your own clutch holding tool that will do the job nicely for next to nothing:
http://www.motorcycleracer.net/phpBB2/v ... tch+holder
The clutch basket does come off the primary gear but it is riveted on and would be a job for a machine shop. Hopefully you got a complete clutch assembly?
Jim
thanks
Posted: Fri Aug 07, 2009 11:46 am
by Brett Kerby
Thanks Jim, I did get the whole clutch pack, and I am going to weld a bar on one of the extra clutch plates. Used a pair of vice grips and they slipped so the welder is coming out for sure..........Appreciate your post very much...
