I am planning to upgrade the voltage regulator. Was hoping others may have updated suggestions?
I was looking at this Ebay item:https://www.ebay.com/itm/153696872394?f ... ondition=3
Thanks.
Best rectifier/regulater replacement 2025?
- Suzuki 2-Strokes: 1974 T500 & 2007 GXS-R 600
- Country: United States
- Suzuki 2-Strokes: GT750, GS1000s
Re: Best rectifier/regulater replacement 2025?
I am still very happy with the rectifier and regulator I bought here a few years ago for my Water Buffalo.
http://www.oregonmotorcycleparts.com/Products.html
T700, Africa Twin, Goldwing, Super Tenere, WR250R, TDR250, GS1000s, GT750, H2 750
- Country: us
I believe the item you linked is only the rectifier, not regulator. I am assuming you are talking about a T500. The Suzuki twins use a single phase charging system while the triples use a 3 phase system.
I replaced my rectifier/regulator with a Tymion unit, it involves some wiring changes.
Rex's speed shop in the UK sells a plug and play combo unit,part number RR12v-31
I am not sure if any other offers plug and play replacement.
It does pay to upgrade, considering the stock system can put out 16-18 volts, problematic for lights and AGM batteries.
- Suzuki 2-Strokes: GT500A - 1976
I’m using the Rex’s speed shop reg/rec on my GT500. Slightly different part number to the one mentioned.
Reasonably priced and faultless so far.
For the twins (T500/GT250/T350/T250) I upgrade to a modern rectifier/regulator. Then you can switch to a modern AGM battery.
I've bee using a Tympanium , or an equivalent.
For info on installing & wiring it, see my old post:
http://www.suzuki2strokes.com/forum/vie ... um#p109480
- joethebike
I followed JABCD’s advice and fitted a Tympanium reg/rect on my T350 so it now delivers a safe, stable 14.3 volts at all revs.
1982 Honda CX500 EC 275,700km
2005 Suzuki DL650 151,500km
