GT 500 GEAR BOX PROBLEM
Posted: Fri Feb 28, 2025 11:06 am
by Steveuk56
Hi, I'm in need of some guidance / ideas regarding a gearbox issue, I've been restoring a 76 GT 500, the engine and gearbox seemed fine before and have done no work on the bottom end of the engine other than replace the rear chain and removing the gear lever to fit a new clutch cable. Now its seems stuck in neutral and won't change up or down while spinning the rear wheel. Any idea's on what could be causing this ???
Thanks SW
Re: GT 500 GEAR BOX PROBLEM
Posted: Fri Feb 28, 2025 6:22 pm
You probably undid the wrong bolt when you drained the gearbox oil. The 'other bolt' is the gearbox dêtent which affects the gearchange cam.
Posted: Fri Feb 28, 2025 6:47 pm
by badgereng
Your post doesn’t actually mention that you drained the oil so it may well not be the cause.
However, if you did drain the oil and chose one of the three hex head bolts that look like drain screws on the lower crankcase, make sure you unscrewed the one furthest to the rear of the engine that also sits the lowest.
The two nearer to the front of the lower crankcase that sit side by side in the cross direction approx 60mm apart relate to the gearbox as stated by previous poster and don’t need to be removed for a simple oil change.
PM me your email address if it’s not clear enough and I’ll send pics that explain better than my verbiage.
Hope you get it sorted
Pete
Posted: Sat Mar 01, 2025 12:11 am
by Steveuk56
Thanks for reply's, your right removed 1 of these bolts when changing the gearbox oil. Hoping that I can fix without 2 much dismantling.
BADGERENG i PM you my contact details, thanks for your help.
Steveuk56
Posted: Sat Mar 01, 2025 5:26 am
by Steveuk56
Hi , Now that i have managed to get it stuck in neutral by removing the bolt , the bolts back but how do i correct the gear shift now ?
Thanks Steve
Posted: Sat Mar 01, 2025 2:36 pm
by badgereng
Steveuk56 wrote: ↑Sat Mar 01, 2025 12:11 am
Email on the way Steve…. I’m sending some pics
Steveuk56
Posted: Mon Mar 03, 2025 4:00 am
by Tailchaser1960
FYI BADGERENG - Can I send you my email address to receive the pics that you kindly sent to Steveuk56 as I too am confused by which bolt is which and need to do a gearbox oil change.
many thanks,
Jeff
Posted: Mon Mar 03, 2025 12:32 pm
by badgereng
I have deleted the email from my sent items as it was quite a big file.
Yep, send away…..
I’ll see if I can recover the email
Posted: Tue Mar 04, 2025 3:12 am
by badgereng
Email has been recovered from the server Jeff.
PM me your email address and I’ll fwd on.
