T500
Monkey man
Suzuki 2-Strokes: T 250 t500 gt 550
T500
Post by Monkey man »
Hi guys I’m back again needing help `I recently checked the timing and think I have it spot on ( even though I had to narrow the points gap to enable alignment with the timing marks) The bike starts and idles ok but out on the road there is a lag right through the gears but it does eventually rev right up when it picks it’s heels up - it’s hard to describe but I liken it to turbo lag in a car
Any ideas what to check next ? Thanks
Re: T500
If the points gap is smaller than it should be, the condenser doesn't fully charge as the points aren't open 'quite' as long as they should be, this means you get a weaker spark and the engine can feel flatter than normal. If you want 'right' performance, you have to have 'right' timing.
Monkey man
Re: T500
Good point and sound advice - looks like it’s new points are needed then
