Fuel Lines
Posted: Fri Feb 17, 2023 9:39 am
by grumpy56
Does anyone know the inside and outside diameters of the fuel lines for an early J model 380? Also, the vacuum hose attaches to the middle carb, but appears in the parts manual to include a spring cover. I can't locate one so would just make one up I suppose with regular fuel line. Thoughts? Thanks.
P.S. If anyone has a pic of the routing of the choke and throttle cables under the tank it would be appreciated. Almost finished with this build from parts 380.
Re: Fuel Lines
Posted: Sat Feb 18, 2023 3:57 pm
by grumpy56
Going to try 5mm X 8mm line and use the spring sheathing on the vacuum line. Still could use pic of throttle and choke cable routing. Thanks.
Re: Fuel Lines
Posted: Sun Feb 19, 2023 4:06 am
The fuel lines are 5x8.2 mm. I use 3/16”.
If you take a close look at the various pics in a shop manual, that will give you some clues of how Suzuki originally ran the cables.
My 72 GT380 has a 1974 motor & lower handlebars, so isn’t a useful basis for the “correct” cable routing.
Re: Fuel Lines
Posted: Sun Feb 19, 2023 8:56 am
by grumpy56
thanks jabcb
