Parts Wanted: 1975 GT 250 Battery Lead Wires
soloZ06
Suzuki 2-Strokes: GT 250
Post by soloZ06 »
I'm looking for the lead wires for the battery on my GT 250 36860-32000. If anyone has one to sell or knows where I can get the correct size two-pole connector so I can build one, I would appreciate it.
Thanks,
Patrick
Re: Parts Wanted: 1975 GT 250 Battery Lead Wires
If you are replacing the original wiring there, why not use single wire bullet connectors and 2.5 sq mm multistrand copper wire (not sure what that is in US wiring size) would carry 30 amps which is plenty. No-one will see it under the side panel. Don't forget a new fuse carrier on the positive side.
soloZ06
Post by soloZ06 »
Yeah, I was wanting something close to original especially sine I have one side already. If I can’t find anything, I’ll go with the two bullet connector option.
You can get the correct connector from Vintage Connections.
http://www.vintageconnections.com/Products/Connectors
soloZ06
Post by soloZ06 »
Exactly what I was looking for. Thanks!
