Having been a member of the Kettleclinic for some years, I realised that I haven't done an intro on here.
I had a GT550A for 14 years, which I sold last year after losing confidence in it. Two full engine rebuilds and still not 100% with it, in a moment of madness I sold it last August. I immediately missed having a 550 so in September I aquired one that had been known to me for some years, a 550B. It had had a nut and bolt restoration 8 years ago, but still needed few running issues sorting out.
So far I've found that only one Sris valve works, one was seized and the other had the ball bearing in at the wrong end of the spring. New valves sorted that. Carb slide adjusters were all loose and had moved out if sync. Flow meter on them and now running nicely, although there is a slight top end rattle on a closed throttle. Still to be looked at. Oil pump was leaking from the spindle, but I had a spare gifted to me. Front brake was very poor. The caliper had been powder coated both inside and out, so the pad did not sit in the hollow and was on an angle. No 'O' rings on the pins and no dust rubbers fitted. All now fixed.
I am surprised that a bike that has had £1,000's spent on it has such issues, but perhaps that's why I'm now the owner. Still more niggles to work through over winter. Carbs off next, over winter for a good check.
I live in East Yorkshire and during the summer months I am regularly at Seaways cafe and Willingham Woods. So give me nod next summer if anyone sees me.
Cheers, Paul.
Alan - I have tried to add a picture, same as I would on the Kettle clinic Forum, but however I try I get an invalid file message ?
Introduction
- Harrymail
- Country: United Kingdom
- Suzuki 2-Strokes: Currently looking
Introduction
Currently looking for a Suzuki GT
1968 BSA Bantam Sports Red
2020 Triumph Street Twin
Re: Introduction
Welcome to the forum.
I use Flickr, it’s free to post lots of images. And include links to those images on posts here.
Re: Introduction
Same here. I'm awaiting developments. I'm not convinced it's not just calling us 'invalids'.......
Re: Introduction
Hi and welcome.
It does show that even supposed 'nut & bolt' restorations need going over with a fine-toothed comb. In Classic Mechanics one of the regular contributors bought a Kawa H2C which had been "completely restored" by a well-known restorer, yet had the gearbox die within 200 miles, oil lines leaking at the banjos, shot fork seals etc etc.
Hope you get yours all sorted.
Re: Introduction
Just as a point on sris valves (or oil line non return valves).
If someone has them apart, or they are incorrectly manufactured, they will only work backwards. Also sris valves and oil line valves are opposites in that they work in opposite directions, so make sure they are ok before fitting.
- Harrymail
Re: Introduction
Two of mine were working backwards. Either been apart or something poked inside and the ball bearing pushed through the spring. After buying new ones I opened the old ones up to take a look inside.Alan H wrote: ↑Sun Nov 28, 2021 8:32 am Just as a point on sris valves (or oil line non return valves).
- jaybe64
- Suzuki 2-Strokes: 1976 GT550
Re: Introduction
Welcome to finally introducing yourself .
