Oil Level
Posted: Tue Sep 28, 2021 10:51 am
by Mark Reeves
Please could some one confirm how to check the engine oil level as there is no dipstick or sight glass that I can see. Also what oil is used.
Re: Oil Level
Posted: Tue Sep 28, 2021 12:31 pm
Use the oil level screw bike on centre stand on level ground, or even better, drain the oil and fill with new.
AFAIK, all the 250 gearboxes are similar capacity - see attached pic.
Use the vertical drain under the engine - NOT the one on an angle as that is the gearchange détente and has a spring and plunger held captive.
Re: Oil Level
Posted: Wed Sep 29, 2021 4:32 am
by dollydog
you've been playing withh 550's too long alan. the 250 has 2 drain plugs, one under the gearbox and one under the clutch compartment, both for draining oil
![Very Happy :D](./images/smilies/icon_biggrin.gif)
but, as you say, it's easier and more accurate to drain the oil and refill - after refitting the drain plugs of course - with 1300cc of 20/50 engine oil. sometimes you find an oil filler plug with a dipstick attached, but they aren't very accurate. the oil level hole ditto. for piece of mind i drain mine, measure and refill. don't forget, if the gearbox oil level drops too much then one of your main bearings will starve and seize
Re: Oil Level
Posted: Wed Sep 29, 2021 5:24 am
Aha! Never having had a 250 Suzuki (they were too expensive for an apprentice electrician back in the 60s), I thought it would be similar to the bigger 'uns. We live & learn, Ade.
Re: Oil Level
Posted: Wed Sep 29, 2021 11:54 am
by Mark Reeves
Thanks again for the advice lads.
