Morning all, almost forgot what it’s like to be up this early for work
I have a problem, I brought a gt550 frame and bottom end off eBay to start my project, frame number and engine numbers are good but I have no number plate and no logbook I’ve been told I can get a certificate from a Suzuki owners club but the link on google doesn’t seem to work
Any ideas ?
Next problem!
- Country: Uk
- Suzuki 2-Strokes: 74 gt550
Re: Next problem!
Talk to dvla. Good luck, you'll need it.
A short introduction on here is always a good way to start. Just who and where you are plus a bit of your biking experience will do.
And photos of the bike. We really like those.
Check your numbers here - http://www.ozebook.com/compendium/suzi/ ... engnos.htm
- Country: United Kingdom
- Suzuki 2-Strokes: 1966 T20
Re: Next problem!
The VJMC has a dating service that should be able to sort you out with the DVLA. Its available to non-members also. You may need to complete your project first before they will issue a registration though?
Keith
Keith
1948 Scott Flying Squirrel
1951 Cyclemaster
1966 Suzuki T20
1981 Montesa 349
1985 Suzuki RG500
1999 Honda CRM250AR
Definately NO 4 strokes
1951 Cyclemaster
1966 Suzuki T20
1981 Montesa 349
1985 Suzuki RG500
1999 Honda CRM250AR
- Country: england
Re: Next problem!
try this bloke https://www.ebay.co.uk/itm/Classic-moto ... 1438.l2649
Re: Next problem!
VJMC will give you details of year and model, but if you can't prove ownership of the bike, there will be difficulties registering it, or at best you might end up with a Q plate, and DVLA don't like issuing them nowadays.gammakeith wrote: ↑Mon Jan 04, 2021 2:33 am The VJMC has a dating service that should be able to sort you out with the DVLA. Its available to non-members also. You may need to complete your project first before they will issue a registration though?
Keith
Re: Next problem!
I don't know if it helps but the VJMC published a guide to reregistering a few months back. It did mention the situation when you don't have a NOVA form. Apparently, you now still have to fill in a NOVA even for UK applications. It did say this is not as bad as it sounds as you don't need to fill in all sections. As you point out, I assume there will be a section for describing how you came to be in possession of the bike? If it helps, I'll see if I can find it and scan.Alan H wrote: ↑Mon Jan 04, 2021 1:18 pmVJMC will give you details of year and model, but if you can't prove ownership of the bike, there will be difficulties registering it, or at best you might end up with a Q plate, and DVLA don't like issuing them nowadays.gammakeith wrote: ↑Mon Jan 04, 2021 2:33 am The VJMC has a dating service that should be able to sort you out with the DVLA. Its available to non-members also. You may need to complete your project first before they will issue a registration though?
Keith
Keith
1951 Cyclemaster
1966 Suzuki T20
1981 Montesa 349
1985 Suzuki RG500
1999 Honda CRM250AR
1951 Cyclemaster
1966 Suzuki T20
1981 Montesa 349
1985 Suzuki RG500
1999 Honda CRM250AR
