Gt 250 regulator output.
Tapnell
Suzuki 2-Strokes: 1973 GT250
Post by Tapnell »
Hi Guys, I’ve just fitted a modern Reg/rec to my 1973 250 to replace the silicon diode rectifier. Voltage measured at the battery rises from 12.5V to a max of 14.6 at high revs. My question is, will a modern sealed AGM battery be ok to use with that voltage input?
GTandcbr
Country: WALES
Re: Gt 250 regulator output.
Post by GTandcbr »
You are fine to use that battery its the lithium battery you have to avoid, because they are charged at a set rate and can catch fire if overcharged :shock:
98 carb Blackbird and GT550j
Tapnell
Post by Tapnell »
GTandcbr wrote:You are fine to use that battery its the lithium battery you have to avoid, because they are charged at a set rate and can catch fire if overcharged :shock:
Many thanks for the advice :up:
