T250 T350 fuel Tap
Posted: Fri Aug 21, 2020 1:06 am
by alanr
Does anybody know how to turn a vacuum tap to manual.l have done it with three of my taps,on,off,reserve all working. If it's been a topic before l wont waste everybody's time.thanks people
Re: T250 T350 fuel Tap
Posted: Fri Aug 21, 2020 3:52 am
by karl pa
I have, but I am interested how you did yours.
Posted: Fri Aug 21, 2020 6:09 am
Please post with pics.
Posted: Sat Aug 22, 2020 3:08 am
by alanr
On,,, off,,,reserve.(bugger of a job uploading photos)
Posted: Sat Aug 22, 2020 8:50 am
by karl pa
How did you modify the internals,I used set screws and epoxy to plug the in and out of diaphragm.
Posted: Sat Aug 22, 2020 8:53 am
Thanks. Any pics of your modifications?
Posted: Sat Aug 22, 2020 2:53 pm
by alanr
Yellow is flow path of "prime"-down tube to right bowl pipe.
Red is flow path of "on"-down tube ,into vacuum, out of vacuum to left bowl pipe.
Blue is "res"-down res.tube,up into vacuum ,out of vacuum to left bowl pipe.
More info tomorrow.
Posted: Mon Aug 24, 2020 4:34 am
by daxman
I bought a dual output manual TAP advertised for a Kawasaki for about 20 quid (maybe less) in spite of reservations it works fine. Screw on spigot type as above..
here you go..
https://www.feked.com/22mm-fuel-tap-cla ... wards.html" onclick="window.open(this.href);return false;
Posted: Mon Aug 24, 2020 3:12 pm
by alanr
Thanks.l brought two of these years ago but I'm after the original look for a restoration and it's fun having a problem and successfully solving it.
Posted: Sun Nov 01, 2020 6:42 am
by quocle603
When I purchased my T500, it had a gravity fed petcock and I noticed the vacuum line on the carb. I thought it was odd but found out that the petcock worked great. Here is a link of one that I found on fleabay
https://www.ebay.com/itm/Fuel-Valve-Pet ... 1438.l2649
