Hi everyone
I’m replacing the cables to the carbs and have taken the old cables off - however i notice one of the cables is shorter than the other two
i’m guessing this is for the middle carb but i’m not so sure
Can anyone advise ?
Gt 750j - replacement carb cables
- Suzuki 2-Strokes: T 250 t500 gt 550
- Country: WALES
Re: Gt 750j - replacement carb cables
Presumably you are talking about the throttle cable. Shortest cable generaly goes to centre carb. If there is a metal elbow on one that goes to right carb
98 carb Blackbird and GT550j
yes throttle cables are what i meant - will make sure i put the shorter cable to the centre carb . Thanks
good evening everyone - my new throttle cables have arrived but are not exactly the same as the ones removed . one of the cables on the new one has a metal elbow on it - Again not sure is this for the centre or one of the outer carbs - Any ideas anyone ?
oops - now i see it - i knew i had read something about it before - not realising it was on my own post
cheers
cheers
