Homemade T20 expansion chambers
Posted: Tue Jun 16, 2020 7:52 am
by truckphone
Hey good morning to the two stroke world! I'm in the process of building a T20 tribute racer and I dont want to spend the $$$ on proper chambers and then have the project go cold. I have a tig welder, metal rollers, and lots of time to plan out the path these pipes will take under my bike. Stock engine, carbs and timing for now so I'm thinking a long skinny pipe. The patient started out as 1966 T20 with lots of rust and dents but seemingly low miles. I'm going to add a full vintage fairing, seat and loong fuel tank, clip ons, rear sets and drum brakes.
My question is can anyone give me the dimensions of a nice mellow chamber for this little 250? I've watched the calculations to design these and it makes my head spin, mathematical stuff isnt my bag. Thanks in advance, when I figure out how to add pics I will show my progress.
Re: Homemade T20 expansion chambers
Posted: Wed Jun 17, 2020 2:19 am
by Craig380
Hi and welcome.
I have a copy of Suzuki USA's tuning bulletin for the T20, which has extensive notes and a schematic of build-yourself chambers. It does warn you sternly that with all the tuning changes, "
the engine will not be usable below 4,000rpm"
You should be able to view / copy them from here:
https://ibb.co/jrx6Z8j" onclick="window.open(this.href);return false;
https://ibb.co/m8J5qgM" onclick="window.open(this.href);return false;
https://ibb.co/BZ27ZCZ" onclick="window.open(this.href);return false;
https://ibb.co/cCVZcdF" onclick="window.open(this.href);return false;
https://ibb.co/X42TYhR" onclick="window.open(this.href);return false;
https://ibb.co/Y0vBL5x" onclick="window.open(this.href);return false;
https://ibb.co/dPdvjY7" onclick="window.open(this.href);return false;
https://ibb.co/Gx4YcrC" onclick="window.open(this.href);return false;
Posted: Thu Jun 18, 2020 3:22 am
by daxman
Interesting stuff
the chamber dims aren't a million miles off the one (so far) I made.. 4" 100mm belly etc.. Interesting to not the suggestion
of 22 gauge sheet which I think is only about .75mm. It explains why I found it so hard to hand roll the 18 gauge (1.2mm) I was using
could be tricky to weld with my hobby mig and rudimentary skills though..
I added a stinger and some paint recently and I've just had a tatty T20 exhaust delivered I plan to hack up for the header..
Posted: Thu Jun 18, 2020 4:36 am
by dollydog
header pipes? the way i've always been told [going back a long time, so should be good for vintage stuff] to make header pipes was this: do you want it for racing or a good spread of power across the rev range. header pipes will be different lengths.
measure the i.d of your header pipe. let's say it's 40mm just for ease. multiply that by 7 or 8 times for racing, or multiply it by 11 times for easy road riding, which i'll do. so, 40 x 11 = 440mm. this is how long the header pipe needs to be - MEASURED FROM THE FRONT FACE OF THE PISTON - to the first cone in the spanny. so, measure from the front face of the piston to the exhaust flange. let's say it's 50mm. factor that into the total length of the header pipe and we get 440mm - 50mm = 390mm. so your header pipe needs to be 390mm long from the exhaust flange to your first cone on the spanny. hope this helps? with modern spannys etc it's probably totally different, but this is old school
Posted: Sun Jun 21, 2020 2:29 pm
by titan performance
Lets see some pictures...
Rolling 1.2 even from mild will be tough. We use 0.9 in mild or s/s and that will roll ok.
Good luck with your project.
Posted: Tue Jun 23, 2020 5:41 am
by daxman
titan performance wrote:Lets see some pictures...
Hopefully something to show soon.. Sadly it will only be one side done. Not looking forward to side 2 although I have some ideas that
might speed up the process
Posted: Sat Jun 27, 2020 2:00 pm
Looking forwards to seeing what they look like.
Those race kit pipes are bit "top endy" as I recall, but they could always have the belly stretched to drop peak torque revs.
Posted: Sat Jul 04, 2020 10:28 am
by daxman
Ok here's my first effort.. The stinger is quite wide and it's loud for sure, (very 'poppy') but not as loud as i expected.. But then again the other side is still a standard exhaust (obvs not going out on the road like this..!)
Posted: Sat Jul 04, 2020 1:19 pm
That doesn't look like a bad effort at all....though to me it has a hint of, upside down about it....or is that just me?
Posted: Sat Jul 04, 2020 4:15 pm
by daxman
titan performance wrote:That doesn't look like a bad effort at all....though to me it has a hint of, upside down about it....or is that just me?
Thanks - it owes a great debt to the mighty angle grinder and flap disc. I think/hope its a trick of the light it should be symmetrical on the centre axis!
Posted: Thu Nov 05, 2020 2:33 pm
by r5baker_
Did you ever get a chance to test these?
Posted: Thu Nov 05, 2020 2:41 pm
truckphone wrote: ↑Tue Jun 16, 2020 7:52 am
One post on June 16th, last visit on June 17th.
Last active:Wed Jun 17, 2020 2:35 pm
Total posts:1 | Search user’s posts
(1 Post / 100.00% of user’s posts)
Why ask then never return to see how folks try to help?
Posted: Tue Nov 10, 2020 4:14 am
by daxman
The second one of mine is almost built cones are welded and I have sourced a LHS header which are like hen's teeth. I've also had to get a LHS cylinder rebored and that is at the machine shop now (long story).
I wouldn't attempt to hand build these again those getting everything 'round' enough to match up for welding has been a proper PITA without the right formers. What has taken me days could probably have been done by a fab shop in hours. however finding a shiop to take on a small job is tricky unless they have an interest in the subject.
Posted: Fri Dec 18, 2020 6:33 am
by daxman
r5baker_ wrote: ↑Thu Nov 05, 2020 2:33 pm
Next sunny day I hope they are both fitted now at least - just nee to remove the centre stand!
Posted: Thu Dec 31, 2020 12:01 pm
by r5baker_
Thanks for keeping with it and looking forward to the results.
