Wanted: wheel hub..
Posted: Thu Apr 30, 2020 2:45 am
by daxman
Hi All
Anyone have an unwanted front disk hub knocking about? I have acquired an 18" alloy rim from an MZ as my chrome one is looking borderline unsound (discovered during tyre change).
I'll use mine if I have to but there's a chance I could cock up the wheel build and leave myself high and dry! PM me if you have owt.
Cheers DM
Re: Wanted: wheel hub..
Posted: Tue Jun 02, 2020 9:16 am
As you didn't say what you actually wanted to fit it to.
I've got a GT550 one you can have.
Posted: Wed Jun 03, 2020 4:33 am
by daxman
Would you believe it!
It's for the 250 so not sure if its the same as the 550 but just yesterday i found one on ebay and bought it.
Posted: Wed Jun 03, 2020 5:00 am
Ah, a bit of good luck finding that one.
The 550 one is similar to the 750, I understand that the 250 and 380 are similar.
Posted: Wed Jun 03, 2020 7:10 am
The GT & early-GS disk brake hubs were all the same, except some of them were not drilled+tapped for two disks.
I moved the brake disk to the left side on a 73 GT250 & a 77 GT380 — both were setup for two disks.
Posted: Wed Jun 03, 2020 7:51 am
My mistake there. We learn something every day. I understood the 250/380 wheels were different to the 550/750s as they are narrower, as are the rims. maybe other bits too (are the wheel spindles same?) There's a blank plastic cover on the non disc side of the hubs, but whether they're drilled or not, I dunno. The part numbers seem to be the same except the 750.
No reason why they should be different I suppose, just a half remembered discussion from years ago.........
Just had a look on Alpha sports and the hub part is different on the 750, but the others are the same.
http://www.alpha-sports.com/suzuki_parts.htm" onclick="window.open(this.href);return false;
I know the GS and GT 550 wheels are interchangeable as I've got GS wheels on the GT and the front goes straight in, I fitted a GS swing arm to the GT (straight swap) as the torque arm mount is on the top rather than the GT's on the bottom. The rear master cylinder was a faff too, but that was another issue......
Posted: Thu Jun 04, 2020 4:42 am
by daxman
Darn, I may have been a bit hasty.. Looking at the one I bought it doesn't look right. No second disk holes and I'm not sure about the speedo drive.
see listing pics..
Thoughts
Posted: Thu Jun 04, 2020 5:18 am
by dollydog
a case of fools rushing in? if you want a gt250 hub i've got plenty. all the spokes, rims etc are kaput, so i'd cut those off. if you want one, just shout
another small useless bit of information, the 750 is different, we know that one, but the gt185 and the x7 are different as well. they've only got 4 bolt holes instead of 6
p.s. i presume daxman that you've spotted that standard pair of gt250a barrels on fleabay?
Posted: Thu Jun 04, 2020 5:38 am
by daxman
dollydog wrote:a case of fools rushing in? if you want a gt250 hub i've got plenty. all the spokes, rims etc are kaput, so i'd cut those off. if you want one, just shout
Could have been
Ah great - thanks will do - thats two offers now in 2 days.. hurrah! I wonder what the one above is? It was listed as GT250 and has 6 disk holes and teh disk looks correct too so I bit quickly.
dollydog wrote: p.s. i presume daxman that you've spotted that standard pair of gt250a barrels on fleabay?
Indeed !
Posted: Thu Jun 04, 2020 11:22 am
Don’t know what that wheel is from.
This pic shows the hub speedo drive for our 73 GT250 cafe build.
Cafe-GT250-0291 by
jabcb, on Flickr
Posted: Thu Jun 04, 2020 12:19 pm
by daxman
Yeah sure is curious.. it looks early. so what were teh first bikes to feature disc brakes. Of course there's no guarantee its Suzuki I guess..
Posted: Thu Jun 04, 2020 3:53 pm
Posted: Thu Jun 04, 2020 4:00 pm
by daxman
Agreed..
Posted: Sun Jul 12, 2020 2:57 am
by daxman
Hi All
Here's the wheel.. it's 'roughly trued and I think within a spec of 1-2mm runout. I didnt have a stand but the mudguard bolt holes are M8 and handily placed and can take a bolt that can be used as guide... Thanks again to DD for teh hub. I fitted new bearings but the old ones still looks and felt good! Loads of grease still on the insides..
