Suzuki S32
- Country: United States
- Suzuki 2-Strokes: s32
Suzuki S32
I'm considering diving into a huge project . Reviving an old S32. Anyone have some pos/neg feedback they can give?
Also what year is frame number with 1203?
- Scorch
- Born to ride
Re: Suzuki S32
S32? Pictures? I have not heard of that model.
Welcome to the forum
Re: Suzuki S32
I don't have any now. Do a search on this site. You will see one Maybe do S32-2
Re: Suzuki S32
I just restored one. On the positive side, they are very simple and easy to work on. The motor is very light and there aren’t many parts. On the negative side, parts are fairly hard to find, and it doesn’t seem very durable. Mine only had 5000 miles on it but nearly all the transmission gears were stripped and the drive hub was cracked. I had to replace a lot of parts.
Look at my thread under the restorations section for details and pics.
Re: Suzuki S32
Best of luck, the older the resto, the harder it gets.
Re: Suzuki S32
Does anyone have a wiring diagram ????
Still trying to find out what year is vin number starting with 1203 ??? Has wide flared front fender
Re: Suzuki S32
OldJapaneseBikes has some VIN info:
http://www.oldjapanesebikes.com/mraxl_G ... /index.php
https://docs.google.com/spreadsheets/d/ ... Ns/pubhtml
SuzukiCyles.org has very little info:
http://www.suzukicycles.org/S-series/S32_specs.shtml
Printed parts & service manuals will be helpful. eBay has a bunch.
This multi-year manual includes parts & service:
https://www.ebay.com/itm/Suzuki-S32-2-p ... Sw2xRYgV4M
Re: Suzuki S32
https://www.cmsnl.com/suzuki-s32-1968-u ... /partslist" onclick="window.open(this.href);return false; might be of use.
Re: Suzuki S32
what other spark plugs can be used beside the NGK B-77C
Re: Suzuki S32
ANYONE ????????
Re: Suzuki S32
Accel 123
Autolite 353
Bosch 0241245592
Bosch W5EC
This is what a quick google search came up with. I would recommend going to an auto parts store and they can cross reference. I cannot get to my bike until spring, otherwise I would look and tell you.
Autolite 353
Bosch 0241245592
Bosch W5EC
Re: Suzuki S32
Is a fully charged 12v battery required to get/check for spark ????
Re: Suzuki S32
Anyone ???????
Re: Suzuki S32
If the ignition is Points & Coil, yes, you will need a battery.
If the ignition is by Flywheel Magneto, no, you will not need a battery.
Cheers Geoff
Cheers Geoff
Re: Suzuki S32
It’s points and coil. Yes you need a charged batteryZunspec4 wrote:If the ignition is Points & Coil, yes, you will need a battery.
Cheers Geoff
