73 GT550 Charging Issues
Posted: Sun Nov 24, 2019 12:55 pm
by mrmach5
73 GT550 not charging so ran tests. I've installed new Rectifier and Regulator for Oregon Electronics just to upgrade the system. After tests looks like the rotor is the culprit and will be replacing the alternator as well.
Question what is the procedure for removing the rotor?
Re: 73 GT550 Charging Issues
Posted: Sun Nov 24, 2019 7:27 pm
by Cliff56
mrmach5 wrote:73 GT550 not charging so ran tests. I've installed new Rectifier and Regulator for Oregon Electronics just to upgrade the system. After tests looks like the rotor is the culprit and will be replacing the alternator as well.
Check the brushes and contact rings first!
You will need a 10x1.25 pitch bolt to remove the rotor.
Posted: Mon Nov 25, 2019 10:00 am
by mrmach5
All set , found the info on the rotor removal in a search, and the homemade tool necessary to pop it off.
