SRIS question
Posted: Mon May 25, 2009 10:41 am
by Coyote
I have (like many others have ) eliminated the recycle system from my 550.
My question is what happens to the injection oil that eventually builds up from the crank bearings oil supply?
Posted: Mon May 25, 2009 3:08 pm
by Suzsmokeyallan
The only way you should have a severe build up of CCI oil in the lower c/case is if the oil line check valves are leaking.
Under normal use, a bike that has been sitting for a while will have a SLIGHT excess of smoke on start up. You would normally see this being burnt off as the small smoke cloud once youre warming the bike up.
If its a real wild fire of smoke that engulfs you and all surrounding persons standing nearby, then chances are you'll need to inspect the check valves and oil pump setting.
From what ive seen with Suzuki over the last 30 plus years of dealing with their two strokes is that they were a bit generous with the supply of oil in the CCI system.
Now that all the modern 2 stroke oils are much better at doing their job, its a double dose of excess for the old CCI system.
Having oil pumps that tended to discharge more oil as they wore in, or out in this case, only compounded the problem.
ANYWAY,,,,, as long as the mixture of oil to fuel ratio by the pump lever setting is giving you a correct looking light tan plug reading, and your check valves are working, all will be fine.
Posted: Mon May 25, 2009 5:26 pm
by Coyote
Bike doesn't smoke at all. And yes the oil pump is set up correctly. If anything - slightly heavy.
But I'm still confused. I mean the whole time the engine is running, oil is being fed to the crank. Logic tells me it has to be emmited or consumed somehow. Hence the SRIS. Without it, what happens to that oil?
Posted: Mon May 25, 2009 6:05 pm
by Suzsmokeyallan
Ok heres how it basically works, the CCI oil from the lines goes to the main bearings where it then spins around and is flung to the edge of the bearing. They have a lip built onto the side of the main bearing facing the crankpin, (the other side has the seal), and an oil slinger on that side of the crank half that the lip on the bearing fits inside of.
So the oil leaves the main bearing and is captured by the slinger due to centrifigal force acting on it.
From here it goes to a hole in the slinger thats aligned with the partially hollow crank pin. It enters the crank pin and then flows out cross drilled holes at the lower con rod bearing section.
From here it then gets mixed with fuel and oil in the lower crankcase and finds its way up to the top end piston pin, along with other oil and fuel coming from the intake oil fitting thats also delivering oil.
So youve got two intake sources of oil in each cylinder, one delivering pure oil to the main bearings first and the con rod and piston pin next, while the secondary one is delivering oil with the intake fuel charge.
So the oil you speak of is being used, its just that it gets diluted and used with the intake charge after its done most of its primary work to lube the main and lower rod bearings.
Posted: Tue May 26, 2009 8:50 am
by H2RICK
Coyote, the main CCI system and the SRIS are not connected in any way and basically have nothing to do with each other.
The SRIS is in place strictly to deal with the buildup of unburnt oil and gas left in the crank chamber after periods of idling.....especially during the first start of the day and/or starts in low ambient temps. The intention is to take that unburned oil/gas mixture and throw it into the next cylinder in the firing order while the next cylinder is on the intake cycle. This method supposedly promotes more complete mixing than would occur if the oil/gas mixture was just sucked up the tranfers of its own cylinder.
Does it work as advertised ?? Yes, in my experience.
Does it reduce visible smoke on acceleration after idling periods ?? Yes....just compare an H1 and a GT550 under the same conditions.
Does it reduce ACTUAL emissions ?? Partly.....although the quantity of oil and gas being burned is still the same, it just occurs differently than on a non-SRIS engine. A 5 gas analyzer could probably pick out the actual emission differences....but that's a moot point at this time.
Kawasaki actually picked up on this idea and its 74 and 75 H2's used a similar system in an effort to keep the EPA happy......if such a thing is/was possible.
Posted: Tue May 26, 2009 10:07 am
by Suzsmokeyallan
Rick id like to see the effects of an SRIS equipped bike versus one with the system defeated, using a gas analyzer
In theory it seems the residual oil would be pumped into the other cylinders to be burnt, but it still gets burnt eventually so the amount of smoke produced from the residue wouldnt be reduced just shifted around till it gets burnt.
Posted: Wed May 27, 2009 8:00 am
by H2RICK
Well, Allan, as mentioned in my post, the theory SEEMED to be that the SRIS would allow the unburned gas/oil mix in, say, the crank chamber of cylinder 1 to be more thoroughly mixed with the incoming "normal" mixture in the transfer ports of cylinder 2. Theoretically this would allow for more complete combustion and less smoke.....evn though the mixture in cylinder 2 would be somewhat richer overall than it would be normally.
Yep, it would be interesting to conduct an experiment with a gas analyzer as outlined in your post. Someday, when you and I are rich and famous and can afford a shop equipped with such an interesting tool we'll do a whole study on this esoteric subject and report our findings to the stroker world.
