suzuki gt250 muffler
- Country: finland
- Suzuki 2-Strokes: suzuki gt250
hi
i did check my bikes muffler because it was so loud.
it seems internal parts have been broken (that part where baffle will rest inside the muffler).
has anyone tried to repair something like this or is best solution to find new muffler?
- Country: WALES
Re: suzuki gt250 muffler
I would just make sure the old baffle is out they sometimes break in half. Then buy a replacement and insert it and put a new screw to hold it in place. I have used mine like this for the last 10 years
98 carb Blackbird and GT550j
- Country: finland
i did make new baffle but sound is way too loud because that piece is broken inside muffler.GTandcbr wrote:I would just make sure the old baffle is out they sometimes break in half. Then buy a replacement and insert it and put a new screw to hold it in place. I have used mine like this for the last 10 years
- Country: WALES
You will have to get that broken piece out or it will never sound right. Try holding it up and gently tapping the seam with a rubber mallet.
- Country: WALES
You could also try soaking the inside of the exhaust with a solvent before doing so.
- Country: finland
i did get the piece out but it sounds terrible because baffle doesnt fit now cause of that piece is broken.GTandcbr wrote:You could also try soaking the inside of the exhaust with a solvent before doing so.
have someone repaired something like this without opening muffler?
muffler is welded all around
- Country: England, UK
I could be wrong but; That looks like a piece of baffle packing has broken off. Are you sure it is a faulty pipe? Have you tried repacking the baffles?
I don't have standard pipes on mine, so hopefully if I am wrong, someone will correct me on what the inside end of a standard pipe looks like without the baffle in it.
- Country: us
- Suzuki 2-Strokes: GT
Looks like the baffle plate that holds baffle in place and isolates muffler chambers forcing exhaust through the baffle is broken, without these plates in place there isn't much you can do to quiet the exhaust. It is common for these to break or come loose when spot welds let go,I think your best bet would be to look for other mufflers, but if they rattle when shaken, they too have broken internals.
- Country: finland
just as i thought...karl pa wrote:Looks like the baffle plate that holds baffle in place and isolates muffler chambers forcing exhaust through the baffle is broken, without these plates in place there isn't much you can do to quiet the exhaust. It is common for these to break or come loose when spot welds let go,I think your best bet would be to look for other mufflers, but if they rattle when shaken, they too have broken internals.
search of the new muffler may begin...
- Country: United Kingdom
- Suzuki 2-Strokes: GT250B
I can cornfirm both my GT250 pipes have loose baffle walls. Seems a very common problem, and not an easy fix.
If you don't like loud pipes, make sure you don't get a set of Higgspeeds to replace the broken ones with. They are nice pipes but I can guarantee they will be a LOUD. So loud that my wife runs indoors every time I start my bike up.
