Float valve and seat Mikuni VM 32
Hello, anybody know where I can get the float valve and seat assembly for a 72 gt 750 Mikuni VM 32 carb 2.5 valve, it seem that they no longer carry these anymore. Called up K&L and other sources and they no longer carry the valve assembly, or if someone knows where I can find the float valve that would work.
- ConnerVT
- Novice racer
Re: Float valve and seat Mikuni VM 32
Believe this is what you need. From Dennis Kirk.
Mikuni VM28/163- Needle and Seat Size 2.5 - VM28/163-2.5
https://www.denniskirk.com/mikuni/vm28- ... 170335.sku
Yep that's what I'm looking for. Thank you
- ConnerVT
- Novice racer
Put them in my T500 a few years back. Work much better than the aftermarket kit ones I first used, which chose to fill my engine case with gasoline.
