T250 Plugs
T250 Plugs
what type of plug caps for T250 thanks,also white disc on speedo has yellowed,how to make it white again,thanks
CB360T
TT250
TT250
Re: T250 Plugs
Personally, I liked to use the platinum or iridium equivalent spark plugs on my 2-strokes, as they never seem to need attention once fitted, and old ignition systems need all the help they can get. These days they are not that much more expensive than standard plugs if you shop around, too. As these always have built-in resistors, I used to use non-resistor NGK caps
Re: T250 Plugs
Electronic with ignition resistor type plug caps, points ignition with non-resistor type.
- Country: England, UK
Re: T250 Plugs
As above, use NGK plugs and caps. By far they are the most reliable and long lasting
Re: T250 Plugs
Yup. NGK are No.1.sportston wrote:As above, use NGK plugs and caps. By far they are the most reliable and long lasting
