Having recently purchased a cable supposedly for my model only to find it too short on left steering lock does anyone have the correct part number or source for my 1974 Titan with slightly lower than standard bars. I want a cable with the curved metal carb ends.
T500 - the correct throttle cable ?
- Suzuki 2-Strokes: none
Re: T500 - the correct throttle cable ?
Your problem could be due to the route you ran the throttle cable. You may be able to reroute your existing cable to solve the problem.
I had of course tried ALL possibilities re routing. The cable was simply too short but for those of you with anything other than flatish bars
you will need part no 58300-15102 and even then it only goes on one way.
