How far carbs into manifold?
- Country: United Kingdom
- Suzuki 2-Strokes: Yr5 t500j
My t500 is the type with just the rubber manifold ,the carbs hardly seem to go in ,only about 10mm is that all they should ? Or aren't i shoving them hard enough? Cheers
- dorT500
Re: How far carbs into manifold?
Sounds good to me with some fresh boots. Here is a pic from Ian's site for comparison....Splant wrote:My t500 is the type with just the rubber manifold ,the carbs hardly seem to go in ,only about 10mm is that all they should ? Or aren't i shoving them hard enough? Cheers
_____________
______________________
No mines the other type i hadn't shoved them in enough last time, theyve gone fully home now ,Rib in manifold into groove on carb ,manifolds were upside down also so cut out wasn't where tap suction pipe goes . I thought the airfilter trunking went on carbs a bit to far!
