Oil banjo bolts thread size ,
Splant
Country: United Kingdom
Suzuki 2-Strokes: Yr5 t500j
Post by Splant »
Trying buy one but they say m6 by either 1.0mm or 1.25mm thread ,nothing's ever simple bought some dome nuts for the rear shocks and ended up with wrong thread sheeesh!
Zunspec4
Re: Oil banjo bolts thread size ,
Post by Zunspec4 »
Hi Splant,
The banjo bolts are specific to the job. They are hollow with a hole on one side so the oil can flow through to the crankcases. The only replacements are originals.
Cheers Geoff
https://rover.ebay.com/rover/0/0/0?mpre ... 2862195354" onclick="window.open(this.href);return false;
Shock nuts.
https://rover.ebay.com/rover/0/0/0?mpre ... 1170148405" onclick="window.open(this.href);return false;
CCI bolts.
Splant
Post by Splant »
Cheers that's good for the dome nuts ,think them bolts are 10mm brake ones, I'll have to get suzuki one it's the oil pump inlet £5 postage is a bit rough though . Thanks
dollydog
Country: england
Post by dollydog »
all metric fasteners on suzukis are standard, normal, everyday thread. m4 is x 0.7, m5 is x 0.8, m6 is x 1.0, m8 is x 1.25. then it all changes. after m8. m10 is x 1.25 and m12 is x 1.5. these last two are classed as 'fine' thread. i think it's just so fastener manufacturers can rip bikers off, paying through the nose for fine thread - typically 2 or 3 times the price. anyway, banjo bolts are normal m6 thread, so just use a normal m6 nut on them when pumping your oil lines full of 2 stroke before fitting. rear shock nuts are m10 fine x 1.25. i usually buy the stainless acorn [sometimes called dome] nuts for them, they last forever. :o
Suzuki used JIS fasteners. As dollydog mentioned, there is one thread pitch for each size.
https://www.mcmaster.com/hex-nuts
Splant
Post by Splant »
So a normal banjo bolt m6 with 1mm thread will fit the oil pump inlet? Will it flow enough oil in to feed the 4 outlets? Or does it only squirt oil down one tube out of the 4 at a time ?
dollydog
Country: england
Post by dollydog »
hi splant, it's your oil pump that does all that work. there's one inlet, which is the threaded boss nearest the oil tank, that feeds the oil pump. the other two are filled by the action of the oil pump rotating. these very, very rarely go wrong. there's 2 different lengths for the banjo bolts too. the main feed from the oil tank to the pump - and the 4 on the engine - are 16mm long. the other 2 at the front of the pump are 13.5mm long. hope that makes sense?
