O h no found out missed a shim out ! T500
Posted: Sun Dec 02, 2018 2:59 pm
Just reading someone else's restoration and he says the oil pump shaft has 2 shims under it I only put one on ! Top one wasn't on before, Checked parts book and it says quantity 2, both 1mm thick ,Is this crucial i was nearly ready for the first start up? I can't work out which way the shaft will be forced when its running ,to work out of its needed.
