T500J swing arm bushings
- 1T500closertodivorce
- Suzuki 2-Strokes: 197? GT 250, 2000 GSXR 600, 1972 T500J
I have my frame stripped down, almost ready to go off for powder coating. I am wondering if someone could talk me through removing the swing arm bushings on my T500. I haven't found a description anywhere to help me. I am asking for the advise before I get too heavy handed!
Also looking for a recommendation for a parts supplier, preferably in Canada, or failing that the US.
Thanks!
Thanks!
- Country: WALES
Re: T500J swing arm bushings
Hi i dont have a 500J but a 550 j i simply used a junior hacksaw, fed the blade through the hole and cut it in two, then knocked it out with a large screwdriver.
New part can be found here:
https://www.partzilla.com/product/suzuk ... 0ff847cc1e" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
Edit. Rule to self don't answer posts when you've been to the pub! I just inserted a long screwdriver and drift it out using the spacer in the middle.
98 carb Blackbird and GT550j
- dorT500
If you don't have a drift tool, see what you can do with appropriate size sockets 1/4" drive and long extension and a hammer. Maybe even turn the socket around....extension 'inside' the socket. One side then the other using the long center spacer as mentioned above. Be sure and remove the grease nipple first.
I guess I should remind you to wear safety glasses.
Great decision to powder coat
.... Something you'll always be happy you did but tell them to take it easy on the numbers and manufacture date stamped on the neck of the frame. I can barely make mine out after I had my frame done back when. I have a reproduction Vin label I have yet to stick on, but still....
_____________
______________________
- dorT500
Hit the spacers harder.
Wasn't real clear before and you probably have them out by now but for future reference for others needing assistance...... there are the two outboard spacers for the swingarm bushings and then the center spacer that looks like this...
After removing the grease nipple, pick a side to start and simply, but aggressively, start driving one of the outside spacers in. All the spacers butt up to each other so the center spacer will push the bushing spacer on the other side out and then eventually the high collar on the center spacer will drive the swingarm bushing out. Then you can just use the center spacer to drive out the other swingarm bushing.
Of course make sure you powercoater blocks of the swingarm tube....it's going to be a tight enough fit as it is when you go to install new ones. Best to try and press them in protecting the lips of course. Even with a rubber mallet trying to hammer them in can chip off some of the lip if you don't protect the bushing from an uneven hit while tapping it in.
I just used the stock bushings from Suzuki myself but as you may know, aftermarket bronze ones are available and here is a link to a 'heads up' from member jabcb.
viewtopic.php?f=7&t=13244" onclick="window.open(this.href);return false;"
_____________
- Country: england
another tip is: don't forget the swingarm is, or should be, loaded with grease. you need to remove it, because if it drips out in its molten state when it gets hot in the powdercoat oven all over everything hanging underneath it, your powdercoater will not be happy. twice this has happened to me, the first time i blanked the end holes up with threaded rod, nuts and penny washers - but i forgot the grease nipple hole. and yes, i left the bushes in, they were perfect. second time i did the same, but blanked the grease nipple hole, blanked the ends off and left the bushes in again - big mistake - somebody had fitted plastic bushes. it melted and spat everywhere, ruining a load of stuff. he was definitely not amused that time
Result!
Thanks for all the good advise!
- dorT500
Excellent!jabcb wrote:I use one of the bushing drivers..
I must admit......I did chip the lip on one of my new fibre/plastic bushings from Suzuki a bit this past summer using a rubber mallet alone.
_____________
- dorT500
Good.1T500closertodivorce wrote:Result!...
Man, you did say in one of your first posts that you were in no hurry on this project. You weren't kidding....it's been awhile but now knowing that powdercoating is part of the plan, I get the sense the wait to see the project will be worth it.
You had also mentioned wanting parts suppliers preferably in Canada. New? Used? or both? You might try googling keywords 'vintage Japanese motorcycle wreckers' and see what pops up.
Have you used this dealership in Vancouver to special order parts they don't normally stock?
Good Luck
_____________
Yes, I'm taking my time , for sure. I can't ride at the moment (long story), so slow but steady will hopefully win the race!
Cheers.
Cheers.
