Suzuki2Strokes.com
Sundial Moto Sports
Suzuki2Strokes.com
It is currently Wed Apr 24, 2019 10:52 pm
Post new topic Reply to topic  [ 10 posts ]
Author Message
PostPosted: Thu Oct 25, 2018 5:29 am
Offline
Bikes owned: GT100, GT500
75 GT500:
- Do not know when was last time clutch cover screws were opened.
- Could be unopened since decades/or two.
- There are marks of attempts to open, since the screws look like almost on the verge of stripped.
- I do not own impact wrench ( thinking of renting or buying cheap/electric used one )
- Will electric impact wrench have enough power to open screws? or only high powered air impact wrench is needed.
- I do not have any experience with impact wrenches, so not sure about its potential and applicability in my situation.
- Is there any other method that I should be trying?
What are my options at this point?
Thanks in advance!
Top
 Profile
PostPosted: Thu Nov 01, 2018 4:53 am
Offline
Bikes owned: 1974 GT185
I've never used an electric/pneumatic impact on these screws. I used a hand impact driver. Pick the correct size bit, and hit the back of the driver with a hammer. Easy-peasy.
https://www.amazon.com/ARES-70006-Rever ... act+driver" onclick="window.open(this.href);return false;
Top
 Profile
PostPosted: Thu Nov 01, 2018 5:07 am
Offline
Buggered up screws is pretty common. The screws on vintage Japanese bikes are JIS, which looks similar but is different to phillips. A phillips screwdriver works adequately for JIS screws that aren’t in very tight, but it will bugger up tight JIS screws like those on your engine covers.
You should get JIS screwdrivers so that you don’t have this problem in the future. I use Vessel screwdrivers, which is a Japanese brand of pro quality JIS screwdrivers. But there are cheaper alternatives.
If your case screws are not too badly buggered up, you may be able to get them out with a Vessel Impacta screwdriver. You hit the end of the screwdriver with a hammer, which forces it into the screw while turning it slightly.
There are also impact drivers with bits that look like this that may work:
You can use a drill to remove the heads of really badly buggered up screws. Once the cover is off, you can use pliers to remove what is left of the screw.
You should replace any of the damaged screws. You can get a complete set of replacement screws here: http://www.rimfire-eng.com/suzukistore.htm
Plated mild steel screws are the same as original. If you decide to upgrade to stainless steel screws, then make sure to use anti-seize.
The little dimple in the head of the new screws identifies them as JIS.
Some people prefer to upgrade to stainless allen screws. Kits are available, just make sure to use anti-seize.
_________________
GT550 72 project & 75
T500 73 project
T350 69, 71 & 72 project
T250 72
Top
 Profile
PostPosted: Thu Nov 01, 2018 2:15 pm
Offline
Bikes owned: TS100, T200, GT250, T500, GT500, GT550, GT750, GS750
I've pulled apart a lot of motors over 40 years, and can't remember not being able to get a screw out with a hand held impact driver and a club hammer.
_________________
Top
 Profile WWW
PostPosted: Tue Nov 06, 2018 8:54 am
Offline
I likes them jubblies
Country: uk
Bikes owned: tracer 700
if your unsure still ,you can always try these.
https://www.ebay.co.uk/sch/i.html?_odkw ... r&_sacat=0
_________________
Top
 Profile
PostPosted: Tue Nov 06, 2018 11:08 am
Offline
Country: United States
Bikes owned: T500
https://www.ebay.co.uk/sch/i.html?_odkw ... r&_sacat=0" onclick="window.open(this.href);return false;
You won't need stud extractors, either use the impact driver others have mentioned above or drill the screw head off then remove the stud that is left with mole grips when the case is off.
Top
 Profile
PostPosted: Tue Nov 06, 2018 3:36 pm
Offline
Country: england
another trick is to shock the screws. you need a long screwdriver bit, put it on the screw and hit it HARD with a heavy hammer. this sometimes does the trick, but as titan performance says, i'm the same, i've never failed to get a screw out with an impact driver. mine was about £5 and works perfectly. if the heads of your screws are knackered, then using the blunt bit [in the impact kit] is your best bet. i replace all my cover screws with stainless allen bolts, they are far better and easy to get out - but as has been said before - make sure you put a smear of copper grease on each one WITHOUT FAIL. you'll find having an impact driver in your toolbox is one of the best things you'll ever buy. oh yes, inside the casing there are more jis screws, that might not be buggered, so make sure you've got a couple of jis bits too :D
_________________
Top
 Profile
PostPosted: Thu Nov 08, 2018 5:39 am
Offline
Country: United Kingdom
Bikes owned: A100 GT250 & 4t Yams!
One last comment.. you can make a passable JIS bit by filing the tip off a Phillips (PH) bit flat so that it sits better in the screw head..
Top
 Profile
PostPosted: Thu Nov 08, 2018 1:15 pm
Offline
Country: uk
someone on FaceBook had use this and found them ok.
so I bought 2.
(( Further to my comment yesterday ref exhaust to down pipe sea l I have searched my spares and have found seal box and seal and checked number on it it is a Payen nb 628 it is a crank/flywheel seal so withstands the heat and at present they are on Ebay for £10.57 but are black not blue but hey dam sight cheaper hope this helps everybody))
https://www.ebay.co.uk/sch/i.html?_from ... 1&_sacat=0
_________________
Top
 Profile
PostPosted: Sun Nov 11, 2018 11:37 am
Offline
Country: England, UK
A great idea, but if you haven't used them before, it is worth noting that they should only be tightened using a screwdriver, NOT a ratchet, t-bar or long side of an allen key. The casing threads are easily stripped if the wrong tool is used.
Top
 Profile
Who is online
Users browsing this forum: No registered users and 25 guests
Search for:
Jump to:
Suzuki2Strokes.com
