T500 crank o rings
Splant
Country: United Kingdom
Suzuki 2-Strokes: Yr5 t500j
T500 crank o rings
Post by Splant »
Can the o rings be stretched over the flywheel webs to renew the centre bearing seals ? And can threebond be used all around the bearing instead of renewing the o rings if they can't be stretched? Cheers
Re: T500 crank o rings
No and no. It has to be split and done properly.
dorT500
Post by dorT500 »
Splant wrote:Can the o rings be stretched over the flywheel webs to renew the centre bearing seals ? And can threebond be used all around the bearing instead of renewing the o rings if they can't be stretched? Cheers
Not in my world. :|
Here are a couple companies you might check out should you decide to have a professional do it. I do not have any personal experience or knowledge of their reputation.
https://www.stneotsmotorcycles.com/page ... ngines.htm" onclick="window.open(this.href);return false;
http://www.pjme.co.uk/acatalog/Crank_Sh ... ding_.html" onclick="window.open(this.href);return false;
Other companies can be found by just entering keywords 'two stroke crankshaft rebuilding United Kingdom' into Google search engine.
_____________
______________________
dollydog
Country: england
Post by dollydog »
try sep in kegworth, i always use them. service exchange parts is their proper name and they do a damned fine job :D
just noticed you're from stoke. i used to live there, just off campbell road :D small world.
