Hi,
I'm working on my 1975 GT550 and it needs a new rear tire one that is on it is a 4.25X18 and is totally dry rotted but holds air. What should I use to replace it with a equal size in the metric size? I will use the bike for highway rides. I need some idea's
Thanks,
Jess
What size of tire?
- Suzuki 2-Strokes: GT550
- dorT500
Re: What size of tire?
Just passing through and saw no other replies for a couple or three days. I offer this for what it is worth.......JessC wrote:............. it needs a new rear tire one that is on it is a 4.25X18
Stock rear rim? If so, just for the record, the 4.25 rear on there is not the stock tire size.
Stock rear rim size is 2.158 inches x 18...... Stock tire size 4.00 inches x 18
Stock front rim is 1.85 inches x 19 ....... 3.25 x 19
Calls for tires to be a matched set, that is, the tread design should be the same front and back.
You might look over this including the allowable tire size on a specific rim size chart.
https://www.denniskirk.com/learn/tire-sizes-explained" onclick="window.open(this.href);return false;"
search.php?keywords=Dunlop&terms=all&au ... mit=Search" onclick="window.open(this.href);return false;"
search.php?keywords=Shinko&terms=all&au ... mit=Search" onclick="window.open(this.href);return false;"
The stock rim sizes and tires are the same for my T500. I've used Dunlop 404's for years but have used Shinko 712's more recently. With both, I have to remove/move the main bracket for the front fender or deflate the tire a bit to pull the wheel out.
_____________
______________________
What front tire do you have? Take a look at the date code on the front tire. Might be time to change both tires.
As dorT500 said, the stock rear tire was 4.00x18. Back in the day, 4.25/85x18 was a performance-sized tire. I didn’t even know that size existed prior to seeing it mentioned on the SmokeRiders website.
Avon RoadRiders are a popular choice. They are available in the original stock sizes. The choices in modern metric sizes are limited because of the narrow rims.
- dorT500
_____________
