Suzuki T500L assistance required
Kiffsta
Suzuki 2-Strokes: T500
Post by Kiffsta »
Gday All
I have recently acquired a 1974 T500 Titan for restoration, alas the engine was locked very badly and it now disassembled and the crank is off getting rebuilt with new seals.
We tried all sorts of trickery to unlock the engine but she was seized solid and after freeing her up, we noticed a crack in the bottom liner, so I located a NOS T500J cylinder and purchased it. It arrived on Friday and I have noticed on the intake that the original barrels had a small amount of casting on the intake whereas my new barrel has a larger section which comes out almost to where the carb manifold bolts on. I did check the parts list for the T500 and noticed 2 different barrel types, one for the first Cobra and a later one that was used on the t500 II , T500 III, T500R and T500J. I could not locate a parts book for a T500L, but I had read there werent too many changes to the engine except for the plastic part to protect 5th gear.
parts list is here - http://www.ozebook.com/compendium/T500parts/image4.htm" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
The guy I bought the barrel off swears it is off a T500J, he purchased a pair, but only needed the RH one, hence why it was up for sale.
So to the Suzuki brains trust on here, can I use a cylinder with a slightly different intake ? if so, and will it happily co-exist with my old RH cylinder ? Or did the T500l ship with different barrels to the T500J ? if anyone has a link to a T500L parts book, it would be greatly appreciated.
Attached is a pic of the bike and the barrels and head after I wet blasted them.
thanks
Chris
Brisbane Australia
Re: Suzuki T500L assistance required
Hi and welcome. Looks like a nice project you have there.
I don't know if there's a T500L parts book here, but it is a goldmine for Suzi 2-stroke manuals: http://www.oldjapanesebikes.com/mraxl_GT_Resource/" onclick="window.open(this.href);return false;
The crack in the liner looks like it's just at the bottom of the barrel where it goes into the crankcases, I would think it's possible to get it carefully welded so that it's solid again ... after all, that part of the liner is only there to guide the lower skirt of the piston, it doesn't have to hold compression or anything. As long as the liner is smooth on the inside where the piston skirt passes it, it will work fine. The liners are cast iron so it should be easy to stitch it with the torch.
dorT500
Post by dorT500 »
Kiffsta wrote:......I have noticed on the intake that the original barrels had a small amount of casting on the intake whereas my new barrel has a larger section which comes out almost to where the carb manifold bolts on...... So to the Suzuki brains trust on here, can I use a cylinder with a slightly different intake ? if so, and will it happily co-exist with my old RH cylinder ? Or did the T500l ship with different barrels to the T500J ?
This took a bit of doing but I remembered a couple of keywords to search the archives that I remember back in 2007 from the old Sundial site for when the subject, that I know of, first came up. I had uploaded some pictures from that thread or from somewhere else of the difference in the ports but I was using photobucket and I'm not sure I can get back in there now.
http://suzuki2strokes.com/forum/viewtop ... start=5145" onclick="window.open(this.href);return false;"
http://suzuki2strokes.com/forum/viewtop ... nce#p86361" onclick="window.open(this.href);return false;"
http://suzuki2strokes.com/forum/viewtop ... nce#p60712" onclick="window.open(this.href);return false;"
_____________
______________________
dorT500
Post by dorT500 »
I just noticed :oops: , that is an early 1200cc capacity crankcase ...or at least the top half of one. Not a 1974. I guess you have already realized that....you had mentioned in passing about the oil dam part. Makes me wonder which carburetors you have also.
Bike looks nice.....excellent candidate for your restoration plans and Welcome to Sundial
_____________
Kiffsta
Post by Kiffsta »
thanks for your warm welcome and advice, I tracked down a T500L parts book and the pn's are most definitely different
T500
LH 11220-15001
RH 11210-15001
T500II, T500 III, T500R, T500J
LH 11220-15100
RH 11210-15100
T500L
LH 11220-15301
RH 11210-15301
so now I am at a crossroads, I posted on the ozebook Facebook page chasing some replacement barrels and was told it is okay to cut away the broken section, the guys on there on posted these pics.
Kiffsta
Post by Kiffsta »
dorT500 wrote:I just noticed :oops: , that is an early 1200cc capacity crankcase ...or at least the top half of one. Not a 1974. I guess you have already realized that....you had mentioned in passing about the oil dam part. Makes me wonder which carburetors you have also.
Is there a way to identify my engine build year from the engine number ?
dollydog
Country: england
Post by dollydog »
engine numbers should be as follows:
1971 - 30848 up to ????? 1972 engine numbers missing off my chart.
1972 - ????? up to 59779.
1973 - 59780 up to 68083.
1974 - 68084 up to 74198
hope this helps? :D
That's a good point about cutting away the broken section, as those sections are at the side of the piston it shouldn't make any difference. The piston skirt is still supported at the front & rear. If the cylinders are otherwise OK and within spec apart from the crack in the liner, I'd suggest just cutting the buggers and smoothing off the corners, as per the pics. :up:
Kiffsta
Post by Kiffsta »
dollydog wrote:engine numbers should be as follows:
hope this helps? :D
Mine is 7023x, definitely a 74 then
dorT500
Post by dorT500 »
dorT500 wrote:I just noticed :oops: , that is an early 1200cc capacity crankcase ...or at least the top half of one. Not a 1974.....
Kiffsta wrote:......Mine is 7023x, definitely a 74 then
Again, the upper half of the crankcase you showed is from an earlier crankcase. It is not from a 1974. You can poke around the info below if you want but the main thing to know for sure is if you need or want to do the oil dam modification. It appears that you won't have to if that bottom half is a 74 or 75....factory would have corrected it by then and stamped the top 1400cc but just to know for sure, you can do a quick measurement......
Just a matter of how far to correct you want to go on your restoration.
viewtopic.php?f=2&t=13671" onclick="window.open(this.href);return false;"
Here is a '75 with the 1400cc stamp....same as my '74 spare crankcase assembly that is in my '75 T500.
http://suzukits.informe.com/wiki/view/S ... _1971-1981" onclick="window.open(this.href);return false;"
http://www.ozebook.com/compendium/techb ... %201-5.pdf" onclick="window.open(this.href);return false;"
http://www.ozebook.com/compendium/t500_files/oilmod.htm" onclick="window.open(this.href);return false;"
https://www.oldjapanesebikes.com/mraxl_ ... ems/page-5" onclick="window.open(this.href);return false;"
viewtopic.php?p=106975" onclick="window.open(this.href);return false;"
_____________
dorT500
Post by dorT500 »
...and just for the record, here are the stock carbs (note number) for the '74,'75 T500 and U.S. '76 GT500 engines......
_____________
Kiffsta
Post by Kiffsta »
My carbs are most definitely 153 13’s , I pulled them down for a clean and after sitting for 12 years , they were spotless with the exception of some dust in the bowls, they do have 97.5 jets .
Engine assembly was going well, crank is now installed , my new Wiseco pistons are in , but I found an issue with the oil pump , it is binding and doesn’t spin freely . I have pulled the pump down and found some wear on the shaft gear so I am now in the market for a decent working oil pump in Australia , can Anyone help me out?
dorT500
Post by dorT500 »
Kiffsta wrote:....... but I found an issue with the oil pump , it is binding and doesn’t spin freely . I have pulled the pump down and found some wear on the shaft gear.....
Just to make sure the binding problem is not something else before you get another pump.....perhaps a previous owner screwed in the REVERSE THREAD plunger guide screw without moving the plunger forward a bit via the pump lever first. This would guarantee setting up correct alignment at end of plunger ramp, not on top of the plunger end.
Just a heads up. Here's hoping you find another pump if the above is not the issue.
_____________
Kiffsta
Post by Kiffsta »
There is a cool animation of the oil pump on YouTube which I watched to see how it worked , see https://youtu.be/1x5Dau9N9cg" onclick="window.open(this.href);return false;
Once I pulled the pump down, I can see the gear section in the main shaft has some minor flat spots which is causing the binding , I can only assume that someone put it in a vice at some point. So the hunt it on for a pump or just the shaft , I found some on eBay but they are quite expensive.
Kiffsta
Post by Kiffsta »
I want able to track down a cost effective oil pump, but of the t500 Facebook group members had both shafts and sold them to me quite cheaply. I have now put the engine back in and installed the newtronic electronic ignition , super stoked, she is now a runner. A few tidy up jobs then it will off for a road worthy cert and registration
