GT250A - brass rod thingy in cylinder intake port
daxman
Country: United Kingdom
Post by daxman »
Hi All
is it part of the autolube system ? If not can you tell me what it does?
Ta.
GTandcbr
Country: WALES
Re: GT250A - brass rod thingy in cylinder intake port
Post by GTandcbr »
Hi, it squirts oil into the air/fuel mixture and lubricates cylinder walls and piston crown.
98 carb Blackbird and GT550j
daxman
Post by daxman »
Ah thanks- more or less what I guessed. So a good idea to check for blockages on my replacement cylinder!
dollydog
Country: england
Post by dollydog »
hi dax, you can actually remove these if necessary :D the barrels i had didn't have any, so i pinched some off another totally knackered set. turn the barrel upside down and drift them inwards - into the inlet port. they are actually slightly wider at the bottom than the top, so you can't put them in upside down :D
sportston
Country: England, UK
Post by sportston »
dollydog wrote:hi dax, you can actually remove these if necessary :D the barrels i had didn't have any, so i pinched some off another totally knackered set. turn the barrel upside down and drift them inwards - into the inlet port. they are actually slightly wider at the bottom than the top, so you can't put them in upside down :D
Interesting. How did you put them back in?
dollydog
Country: england
Post by dollydog »
the same way you get them out. sit them in the hole and tap them in til flush :D
sportston
Post by sportston »
Interesting thanks
Always check that they are clear - especially if you flattened the end over with a pin punch. They are designed to feed oil into the center of the air flow for better dispersion, but at low throttle positions there isn't a lot of flow up there anyway.
We take them out when porting a cylinder and don't put them back. The oil still finds its way into the cylinder.
dollydog
Country: england
Post by dollydog »
hi tz, yes, forgot to mention that. i put a 2mm drill through them after tapping them in - just in case :D one thing on the gt250a is the feed goes to one side of the bridge for some reason. on the ramairs it's central. wonder why?
