Piston Ring Suppliers
Posted: Wed Aug 08, 2018 4:58 am
by A.Holley
Just checked ring gap on my T500, definitely need to fit new ones.
Can anyone suggest a good supplier of new ones?
I am running GT750 pistons, 0.5 mm oversized.
Even though I am in Australia, I am happy to deal with reputable people overseas.
Regards
Andrew Holley
Re: Piston Ring Suppliers
Posted: Wed Aug 08, 2018 8:46 am
by sportston
A.Holley wrote:Just checked ring gap on my T500, definitely need to fit new ones.
Regards
Andrew Holley
Hi Andrew,
are you sure a set of rings will be sufficient? Have you checked the wear on the bores? A set of rings may be a pointless purchase if you need a rebore and new pistons.
Mitaka and Wiseco make good pistons and rings according to Chris Applebee.
Posted: Wed Aug 08, 2018 11:52 am
by Zunspec4
Hi Andrew,
Rings should be available from Suzuki. Order + 0.5mm (the same as you have at the moment). Unfortunately you need new rings to check bore wear by measuring the gap etc. As sportston says you might then find you need a re-bore anyway. Mitaka are a decent cast piston, or go the forged route with Weisco or Wossner (more expensive).
Posted: Thu Aug 09, 2018 10:58 pm
by A.Holley
Bore and pistons are fine, checked the clearance on them and still well within tolerance.
It’s purely a ring wear issue.
I know I can order them via the local dealer , but I know from experience they will charge like wounded bulls.
Would rather give my hard earned dollars to someone who doesn’t want to rip me off as much .
Andrew
