Sorry... oil question
Posted: Tue Jul 03, 2018 11:05 pm
I am sure this has been discussed over and over again, but my search has failed/frustrated me. I've searched for engine oil, oil change, transmission oil, oil quantity....
I have a 77 gt500b, I acquired this in boxes, and rebuilt from the crank up over last winter using only a parts manual. I have no shop/repair manual, everything I need to find that the parts manual couldn't help, I found from this message board.... I THANK YOU ALL!
Now that the bike is running, it's time to change the oil, Something as simple as that is embarrassing to ask for help! LOL
What is the designated oil drain plug? I know I had the cases split, but I can not remember which one to use.
How much oil? It says 1400cc, so I measure and put in, but the oil check bolt hole pukes oil before I finish! Maybe it has to be on the side stand when checking?
What is the recommended oil? I typically run shell rotella 15/40. but I've been finding the clutch kind of grabs a little and its hard to shift to neutral when idling. (I spent a lot of time adjusting the clutch cable, and its as good as it is going to get)
