Suzuki2Strokes.com
Sundial Moto Sports
Suzuki2Strokes.com
It is currently Fri Feb 22, 2019 11:40 am
Post new topic Reply to topic  [ 5 posts ]
Author Message
 Post subject: Stalling
PostPosted: Tue Jul 03, 2018 11:13 am
Offline
Bikes owned: GT750
I recently repaired the water pump and rebuilt the carbs(amongst a few other repairs) on my 72 GT750 it seems to be running well when i start it up and it drives great unit it gets up to temp then it seems to bog out then stall out. Once i let it sit for a few it fires back up and runs fine. Any advice would be great i'm kind of at a loss.
thanks!
Top
 Profile
 Post subject: Re: Stalling
PostPosted: Thu Oct 18, 2018 2:07 am
Offline
Country: United States
Bikes owned: GT380 1974
thanks!
Very difficult to diagnose from here, but by what you describe it sounds like fuel supply before ignition issue, but both need to be checked to be honest in diag.
Have you checked fuel flow? Sounds like it is starving out once under load, then being replenished as it sits by the side of the road. Unless you have a non-vacuum petcock, a starved bowl will (normally) never fill while not running unless petcock is switched to Prime. But what you describe might happen even in PRIME setting if the filter screen in the petcock is plugged with gook.
Hope that helps you focus on a few things. Go about it systematically from tank inlet to float bowls and you'll find the issue. (Unless it is ignition, then...)
Top
 Profile
PostPosted: Thu Oct 18, 2018 8:23 am
Offline
I'd start with the filler cap. See if it breathes as it is designed to. Air has to enter to replace the fuel that's coming out or else it will stop flowing. If the filler cap is OK daring the tank and clean out the fuel tap. If it's clogged, flow will be restricted.
Top
 Profile
PostPosted: Thu Oct 18, 2018 2:07 pm
Offline
Country: England, UK
Bikes owned: FZ50, GP100, RG125 Gamma, GT380, Bandit 1200S
+1
They're both right. lol
I agree that it sounds like a fuel starvation problem.
TZ's idea of fuel filler cap breather being blocked is a great place to start looking.
Then check fuel filters and fuel tap like Boise suggested.
Top
 Profile
PostPosted: Thu Oct 18, 2018 2:17 pm
Offline
There is just a couple of other things.
Do you have enough coolant? Is there any chance you have air locks causing the engine to get too hot and getting tight?
Another possible cause of fuel starvation that gives similar symptoms is carb icing. What air temperature are you riding in?
Top
 Profile
Who is online
Users browsing this forum: Bing [Bot], Google [Bot] and 51 guests
Search for:
Jump to:
Suzuki2Strokes.com
