Magneto/wiring help please
Re: Magneto/wiring help please
The stock headlight is around 30W. Your LED headlight probably is close to that. You’ve reduced the lighting load by something like 15W (riding around without turn signals, horn & brake light).
The stock alternator is pretty meager. With just one coil, your bike might start charging at 3~4k rpm. It might work out ok if you always keep the revs up, but at parking lots speeds the horn might be useless.
You should wire both coils going to the R/R. The R/R will get hot at high rpm. Make sure you’ve mounted it some place where it gets reasonably good air flow.
You should also check the voltage at a sustained high rpm. The max voltage your R/R controls to is too high for a lithium battery. You need to make sure its OK for a sealed battery.
Larry710
Suzuki 2-Strokes: 1977 GT500
Post by Larry710 »
jabcb wrote:I’ve had good luck with Tympanium rectifier/regulators.
https://www.ebay.com/sch/i.html?_from=R ... h&_sacat=0
Still recommend this?
Yes. Its popular on vintage British bikes. I used it on a GT250 & a T500.
Its great with AGM batteries. The design has been around for some years , so I wouldn’t recommend it for Lithium batteries.
Where did you mount your R/R?
