can anybody identify these forks please?
- Country: england
35mm stantions, 4 stud bottom clamps, definitely drum brake, only marking i can find on them is HF
- Suzuki 2-Strokes: GT185 Ulysses KLR TW CRF
Re: can anybody identify these forks please?
Not GT185 or T350.
- Country: england
i know what they aren't mate - i need to know what they are
They aren’t a matching set.
For the one on the left, the location of the drain screw shows that its for the right side.
For the right one, that looks like a side reflector mounting surface at the bottom. So its likely newer than most of us were thinking.
So far I’m guessing Honda or something unexpected like Harley.
Post a pic of the other side.
- Country: england
hi jab, they are definitely a pair - give me a minute and i'll find a different piccy
right, i'm back. here's a photo of the outside of the fork bottoms
- Country: england
- Flywheel
- Suzuki 2-Strokes: 1974 GT185
I thought those look somewhat familiar, especially the boss for the drum brake. I believe they're from a 1976 Honda MR 250 Elsinore (had one back in the mid 80s). Here's a set on Ebay, they look the same except the one fork's lower leg is missing a fender mount.
https://www.ebay.com/itm/HONDA-CR-250-M ... zY&vxp=mtr" onclick="window.open(this.href);return false;
- Flywheel
Actually these look closer. They're from a Honda MT 250 Elsinore. Difference between the "Elsinore" models: CR- Motocross, MR-Enduro, MT- Dual Sport.
https://www.ebay.com/itm/1974-Honda-MT2 ... jK&vxp=mtr" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
https://www.ebay.com/itm/FRONT-FORKS-19 ... yN&vxp=mtr" onclick="window.open(this.href);return false;
Edit... Maybe a CL250 as well
- Country: england
flywheel, you are a gentleman and a scholar many thanks!
Flywheel, I’m impressed.
Outer left fork tube Honda part # 51521-340-300.
The SL350K2A has a drum brake with a stay that bolts up to the boss.
The XL250A has a drum brake that uses the raised section that I thought was for a side reflector.
Fork tube diameters: http://www.ohiocaferacers.com/OCRTubeSizes.pdf
- Flywheel
Thanks for the kind words. I believe this is a result of my youth: a pre-driver licensed teen scouring the local motorcycle salvage yard trying to keep his dirt motorcycle operational while on a income of a paper route, cutting grass and shoveling snow.
