OIL Pump T250
Doss1961
Country: United Kingdom
Suzuki 2-Strokes: T250 Hustler
OIL Pump T250
Post by Doss1961 »
Hello
I removed a plate from the end of the oil pump which is held on by 3 posi drive screws but it will not fit back flush there is a small tongue on the inside of the plate and I do not want to force it.
Has anyone had one apart before.
Paul.
dollydog
Country: england
Re: OIL Pump T250
Post by dollydog »
easy :D
presume you have the oilpump off? anyway hold pump in left hand. triangular plate can only go on one way and that's the tab to the inside right [as you're looking at it]. press the plate on with left thumb and at the same time press the control arm [the one with the spring on it] back and forth with right thumb until the plate drops on flush. put screws back in and good to go. don't forget the 'o' ring though :D
dollydog
Country: england
Re: OIL Pump T250
Post by dollydog »
that's quite ok mate - anytime, just ask :D
Doss1961
Re: OIL Pump T250
Post by Doss1961 »
Hello DD
Took your advice and tried it tonight and it worked fine screws fitted and back to together just ordered a gasket then I will fit it
Thanks Paul
