Early GT550 clutch on ebay
http://www.ebay.co.uk/itm/1974-Suzuki-G ... 1438.l2649" onclick="window.open(this.href);return false;
Not cheap, but if you need one........
Postage seems cheap, but with import tax to the UK, it's not so good I suppose.
RossB
Country: United States
Suzuki 2-Strokes: RD400 T500 Titan GT550
Re: Early GT550 clutch on ebay
Post by RossB »
To bad no starter clutch gear there getting tough to come by just got one paid $150.00.
The old one is in pieces!
gsx1400dave
Suzuki 2-Strokes: GT550 x3, GSX1400, CR250
Post by gsx1400dave »
Stay away from this.
The starter drive gear is not shown as it will be damaged.
Photo shows only 2 caps, no springs and 3 roller bearings that look damaged (almost square).
Dave
Dave.
GSX1400 K4
GT550 x 3
CR250
"You need only two tools: WD-40 and duct tape. If it doesn't move and it should, use WD-40. If it moves and shouldn't, use the tape. " - Dave Barry, columnist
The caps, springs and rollers are usually available from Francos in the UK. They are the same as the same parts in tbe early GT750 clutch (same part numbers).
