Geoff it was a box of bits and a very loosely assembled engine frame and wheels.Zunspec4 wrote:This is becoming a super puzzle
Starting from first principles: If the lever is going back to the bar it can only be caused by two things.
1. The caliper pistons are retracting to far and thus need more fluid to bring them back to the pad. Except pumping the lever does not firm up the action.
2. If not 1. above there still has to be air in the system (somewhere).
Did you ever have normal lever response before refurbishing everything ?
Cheers Geoff
When applying the brake the pads contact the discs and apply enough pressure to lock the wheel fairly quickly, however the calipers appear to twist away from the disc and the mounts by a small amount (visibly) giving the extra travel in the lever.
Just cant figure out why.
There is no air in the system and there are no leaks.
Starting to get a touch miffed by it now....................
Terry
