Hello everybody, well im restoring a 76 Suzuki gt500 and I changed the bars to lower bars and now my tach cable is to long,does anybody out there
know where to ge a shorter tach cable for a Suzuki gt500 stock is 45inchs I need one that's about 40 or 41 inchs.
let me know ,any help would be great
Bob in Burbank
Tach cable
- Country: usa
- Suzuki 2-Strokes: nonese
- Country: us
- Suzuki 2-Strokes: GT
Re: Tach cable
Just changing bars shouldn't affect tach cable, the tach/speedo bracket bolts to the triple tree, changing bars should only affect clutch and throttle cable, and brake hose.
76 GT185
77 GT250
77 GT380
73 GT550
73 GT750
74 GT750
71 T250 scrambler
75 T500 cafe
77 GT250
77 GT380
73 GT550
73 GT750
74 GT750
71 T250 scrambler
75 T500 cafe
- Country: WALES
Re: Tach cable
There are companies that manufacture bespoke cables here in the UK maybe there are some in the US too?
98 carb Blackbird and GT550j
Re: Tach cable
+1 on karl's comments.
If you have a stock cable, then the extra length is because you ran the cable via a shorter path from the tach drive at the back of the motor to the tach.
You can alter the cable path a bit to use up that 4 inches.
Also, make sure the cable path you chose does not cause a problem when you turn the handlebar to the extreme right or left.
